Arduino Forum Arduino Controlled Greenhouse!
  • Replies 11 replies
  • Subscribers 422 subscribers
  • Views 1657 views
  • humidity
  • garden
  • temperature
  • greenhouse
  • sensor
Hi everyone, while surfing the nets I came across this website (which I think is absolutly wonderful by the way) and I just decided to post one of my project ideas and see if anyone has any input.
Im (attempting) to build an arduino controlled greenhouse (Garduino?).  Right now I am just starting out with a basic temperature sensor ( a TC74A0 running throug an I2C bus) and a humidity sensor (its a capacitance humidity sensor, wired up to an astable 555 chip circut).  In the future I am hoping to add relays that control heating elements of some sort, lights, and a humidifier, all of these would be adjusted with what the Arduino is getting from its sensors.
In the future I am planning to add a PH sensor, and soil dampness sensor.
So what do you guys think? Any suggestions for me?
  • R_Phoenix
    R_Phoenix over 15 years ago
    You might like this
    http://www.sparkfun.com/news/598
  • terryking
    terryking over 15 years ago
    Hi, I have done PC-controlled "Grow Labs" and will convert mine to Arduino next Summer when I get back to USA.
    You might like to find these guys: http://yourduino.com/home-automation.htm
    And when you get to controlling things like watering and passive and active ventilation you'll need to do "Arduino Power!"
    More sensors and stuff here too:
    Please let us know how your project goes!
    DISCLAIMER: I mentioned stuff from my own Shop...
    Regards, Terry King
    ...In The Woods In Vermont
    terry@yourduino.com
  • simon.monk
    simon.monk over 15 years ago
    This is another of those projects I have been wanting to get around to. I will at some point make an Arduino (smarter) version of this for night heating.
    http://www.reuk.co.uk/Solar-Greenhouse-Heat-Sink.htm
  • bobcroft
    bobcroft over 15 years ago
    Hi Andrew, I too am interested in greenhouse automation.  Have had any sucess with the soil moisture detection / measurement ? I would appreciate any information you can share.
    Bob
    e14 Contributor over 14 years ago in reply to bobcroft
    Hi, I have not tried this one personaly, but I read this project (link below) where someone used two nails planted in the soil, and read the resistance between the two nails (the electricity will travel more free in wet soil, and less in dry soil).  Tell me if it works or not image
    http://revoltlab.com/projects/plantduino-greenhouse/
  • DualFlop
    DualFlop over 14 years ago in reply to e14 Contributor
    Hey Andrew,
    I think you would need two concucting plates to build al little capacity. Its value would depend from the moisture between it.
    Sorry to bring up a somewhat dead thread, but google brings it up often for me... I made something along those lines that used temperature and humidity data to control relays as well as different timers. It used an arduino and connected computer system (I was also running motion security cameras on same server...).
    All the sources are available at:  https://github.com/pleasuretek/openGreenHouse  . I am currently upgrading the project to the beaglebone, all sensor logging is put into a postgres database and the relays are controlled using gpio. Check out the version for arduino though, I feel like I took it as far as it could go ( I had started a version with RTC, and ethernet shield and sd card (csv data logging, and relay state machine)).
    I am big into open sourcing the project, as I grow microgreens in greenhouses, and if we could record all of the environment data and feeding data, anyone could take the seeds and grow healthy food anywhere in the world, as long as they replicate the environment. Open source cropware (symbiosis of software, hardware, genetics, and community)
  • YT2095
    YT2095 over 14 years ago
    I used to grow Chilis in mine, and found that it`s Not a good idea to use metals in the soil as these will potentially contaminate it with metal salts, and/or form a oxide layer that will alter the readings over time making them less stable.
    the best thing to use if Carbon (graphite) rods, these wont alter anything, And you can get them quite easily from most Welding suppliers as Gouging Rods, I used the 12mm diameter rods.
    you must peel off the copper foil!
    it`s easy to do with a knife to get started and the rest just peels off, you Can leave a bit of copper on the end to solder your wires to, but these must stay above the surface and idealy put some self amalgamting tape over the copper and wire join to prevent humidity corroding it.
    These should last you for Years!
    all the best image
    e14 Contributor over 14 years ago in reply to YT2095
    I fully agree about the using nails as moisture sensors. They will alter the metals (make unwanted salt buildup) and PH. I have seen professional sensors for this, but I still use the old fashioned way to tell how often to water or feed - test them by hand and know your genetics.  Greenhouse automation can help with some things, but you will always have a long list of chores when caring for plants.
    To my knowledge commercial growers do not measure soil water levels, aside from the issue of remembering to take the things out when harvesting, there are too many variables and potential contamination. They have trouble with soil temperature for much the same reasons. See priva.nl as a commercial agricultural control supplier.
    Concentrate on temperature, humidity, light, and CO2 levels for your best crop.
