Arduino Forum IMAGE PROCESSING USING ARDUINO
  • Subscribers 419 subscribers
  • Views 2030 views
I want to start image processing using matlab and interfacing it with arduino ... actually i want to make a robot which can process image... i am working on arduino platform.... so i want a guide from where to start....
    DAB over 15 years ago
    As I recall, Matlab has an image processing library available, so if you can get the data from the image sensor to Matlab, you can generate command decisions to the Arduino over a number of different interface methods.
    You might want to checkout RobotSee.  It is a robotics library that incompasses a lot of functions in a simple way.
    I hope this helps,
  • fustini
    fustini over 15 years ago
    Hi, not sure about MatLab, but I have seen a couple demos of embedded computer vision that use OpenCV.  However, this really needs much more power than an AVR-based Arduino.  Typically an ARM-based system is used.  Checkout this thread:
    http://www.element14.com/community/message/34407#34407
    Now if you want to do the image processing on a PC with MatLab then you probably don't need beefy embedded hardware to actually run the computer vision software.  But a sufficient embedded system like the BeagleBoard might provide a more mobile solution that would not be dependent on a PC to do the processing.
    In regards to the software, there's another post on OpenCV here at:
    http://www.element14.com/community/groups/mew-imperial-college/blog/2010/12/06/getting-started-with-computer-vision-opencv
    Also, when I was at Maker Faire Detroit, I saw a talk by SimpleCV:
    http://simplecv.org/
    They have tried to provide a higher level of abstraction on top of OpenCV.
    Cheers,
    Drew
    You might want to consider going open source and using Scilab instead of MATLAB and just use a serial port connection.  Online community for help:
    http://www.equalis.com/forums/topics.asp?forum=95169&
  • Ramu
    Ramu over 15 years ago
    One time I participated in a project with MATLAB image processing and outputing data to arduino over serial. So I can tell, tha it is posible. But my modification for this image processing aplication ant arduino was making Matlac to send data to arduino, not the other way araound image
  • cmcleigh
    cmcleigh over 7 years ago in reply to Ramu
    Would you mind to tell me how can you output the processed image to Audrinuo in Matlab
  • clem57
    clem57 over 7 years ago in reply to cmcleigh
    usb to pc...
