Arduino Forum Digital encoder
  • Subscribers 417 subscribers
  • Views 890 views
  • digital
  • pulse
  • pwm
  • encoder
  • analog
Digital encoder
I am trying to read the pwm signal from a digital encoder I got out of a mouse should I use PulseIn or analogRead. Please let me know the best way to do this. Thanks.
  • chgus
    chgus over 14 years ago
    My money would be om pulseIn(), but you might need to monitor more than one pin to determine direction. See for example DASF006380.pdf
    I would probably not use pulseIn either. You need to count state changes, so busy monitoring or attachInterrupt() would match better.
    e14 Contributor over 14 years ago in reply to chgus
    It is only one direction and in not farmiliar withattachInterrupt() could you please explain or is it in the .pdf?
  • chgus
    chgus over 14 years ago in reply to e14 Contributor
    // pin change interrupt example
    // attach wheel input on digital pin 2
    // not all pin's are able to interrupt on change, check documentation
    // these are for Arduino UNO
    #define interruptPin2 0
    #define interruptPin3 1
    volatile int wheelPos = 0;
    void setup()
      Serial.begin(9600);
      attachInterrupt(interruptPin2,moved,CHANGE);
    void loop()
      Serial.print("Wheel position: ");
      Serial.println(wheelPos,DEC);
      // do other stuff
      delay(1000);
    // everytime the wheel pin changes we call this function
    void moved()
      // do simple and quick operations within the interrupt call
      wheelPos++;
    The pdf was just a random example - i have no idea what component you are using
    This is how i would hook up the wheel decoder to test it:
    void setup()
      Serial.begin(9600);
    void loop()
      // do other stuff
      delay(1000);
    void moved()
      wheelPos++;
    Thanks ill give this a try!
    Are you using a encoder of a Mouse...that's great. would you please share the details of project. Even i will love to give it a try.
    Thanks.
    Hi Christer, remember me from STK?
    Regards
    Andy
    Tel.+49-(0)6008-2580173 Haus/House
    Mobile.+49-(0)163-2887669
