Arduino Forum arduino interfacing with a computer
  • Replies 8 replies
  • Subscribers 419 subscribers
  • Views 990 views
  • help
dirtdiver
dirtdiver over 14 years ago
Can I somehow control..say a program or a game on my pc from a button on the arduino, (directly or through processing or whatever)
Im trying to make H shifter for a game.
  • YT2095
    YT2095 over 14 years ago
    I have a feeling the answer is very likely to be Yes, but can we all have a little bit more detail please, what you`re asking is vague to say the very least.
    but off the top of my head, I will say that if you can Already control yout game from the arduino, then it`s a relatively trivial task to control the arduino From the PC.
    serial port using a terminal emulator?, direct parallel port manipulation?, even more exotic things like blue-tooth or xbee or ethernet and yes... even a GSM cell phone image
  • fustini
    fustini over 14 years ago
    Hi - this reminded me of the latest Ben Heck episode where he uses an Arduino in a game controller system.  At one point, he shows an application on his computer displaying the button presses sent from the Arduino:
    http://www.element14.com/community/community/experts/benheck
    You might also want to look at Processing which is a very common method folks use to control PC applications via an Arduino:
    http://processing.org/
    Cheers,
    Drew
  • dirtdiver
    dirtdiver over 14 years ago in reply to YT2095
    I have no idea how to do these image, right now i have a h shifter with two pots acting as axes, and i have a code thats sending 1 , 2,3,4,5,6 over serial  (for the diferent gears)
    i tried to use transistors and a hacked keyboard -the transistor acting like a button ,but im having some issues with that too..
    Yes, you can.  Take a look at the Processing language.  There are also some examples in the Arduino Cookbook.  And you should check out the Arduino Playground for a little more info on using Processing with the Arduino.
    Hope that helps.
  • dirtdiver
    dirtdiver over 14 years ago in reply to e14 Contributor
    i cant find examples of arduino keyboard or something like that..can you point me in the right direction?
    e14 Contributor over 14 years ago in reply to dirtdiver
    Try this thread.
    Check out Arduino Cookbook, chapter 4. (check out table of contents on that link)
  • dirtdiver
    yea, im heading towards the processing idea but i have never worked with it and i will appreciate some help from people who have experience with processing
    how can i send information trough serial and have processing press a key on the keyboard image
    Check out the Robot class for Processing (has an example of controlling mouse), if you can already send serial data to PC, you can use Processing to pick up the serial message and manipulate pointer using Robot Class.
    And here is how to send a key press event, but it is in pure java rather than processing.
