Arduino Forum Arduino-1.0 and time.h
  • Subscribers 417 subscribers
  • Views 1021 views
I am trying to upgrade a sketch to Arduino 1, but get compilation errors.
This sketch was functioning perfectly with Arduino Alpha.
I want to store second() in a string.
#include <Time.h>
#include <SoftwareSerial.h>
String ds;
void setup()  {
  setTime(21,05,00,14,1,2012); // set the time
  ds = String(second());
  delay(1000);
void loop(){
The compiler returns the following error :
C:\arduino-1.0\libraries\Time\Time.cpp:268: error: 'millis' was not declared in this scope
Is time.h not compatible with Arduino-1.0 ?
Thanks for your help.
I am trying to upgrade a sketch to Arduino 1, but get compilation errors. This sketch was functioning perfectly with Arduino Alpha.
I use time.h  to get the time and date as: second, minute, hour, day, month and year.
#include <Time.h>
String ds;
void setup()  {
  delay(1000);
void loop(){
  • fustini
    fustini over 14 years ago
    Hi - I believe this is because Time.cpp includes WProgram.h instead of the newer Arduino.h.
    In <your-arduino-1.0-directory>/libraries/Time/Time.cpp, try changing line 24 from:
    #include <WProgram.h>
    to:
    #include <Arduino.h>
    Cheers,
    Drew
  • ntewinkel
    ntewinkel over 14 years ago
    You might need to download the (new) library and copy it into your Library directory:
    http://arduino.cc/playground/Code/Time
    e14 Contributor over 14 years ago in reply to fustini
    Hello
    Once again thanks Drew. It works now.
    Hello Nico,
    I have downloaded the library and modified the WProgram.h as suggested by Drew. Now it's working fine.
    Thanks.
    Mario
