Arduino Forum Is it Possible to recreate a complete Analog circuit on a arduino
  • Subscribers 419 subscribers
  • Views 727 views
Sorry for the Noob question, but
Is it possible to program/recreate a complete analog circuit on a arduino chip
Thanks for any help
Del
  • fustiniadmin
    fustiniadmin over 14 years ago
    Hi Del,
    I moved your question over here to the Arduino group where it should get more attention from Arduino experts.
    Drew
  • billabott
    billabott over 14 years ago
    The arduino's I/O pins come in two flavors:  digital and analog.  The analog pins contain a DAC (digital to analog converter) with a 10 bit resolution (as best I can recall; confirmed).  So that is a 0 to 5 volt range broken into 1024 steps.  The size of these steps is approx. 4.88 millivolts.
    If this does not answer your question then you should supply some more contextual details.
  • nermash
    nermash over 14 years ago
    Explaining what do you mean by "complete analog circuit" would probably help a lot...
    e14 Contributor over 14 years ago in reply to nermash
    Sorry for the vagueness of my original post, the analog circuit I would like to recreate is a metal detector
    I don't have the circuit diagram that I want to use but this is a circuit similar to the circuit I was wondering if possible to program a arduino to function like this circuit.
    Sorry for the lack of information
    Regards
    Del
    PDF of a similar circuit http://www.geotech1.com/pages/metdet/projects/coinshooter/coinshooter.pdf
  • billabott
    billabott over 14 years ago in reply to e14 Contributor
    Oh, so possibly the real question here is: "How does one connect or interface an analog circuit to one of the I/O pins of the arduino?"
    The answer clearly would be to carefully match the impedance of the two circuits with a not very expensive custom impedance matching circuit.  This is not a non-trivial undertaking, even for experts.
