Arduino Forum Hello everyone.
  • Subscribers 417 subscribers
  • Views 529 views
Hello everyone.
Well after watching Mr. Blum on youtube for about two hours straight, I decided to go down to RadioShack and pick up an Uno. I am sitting here several hours later with a huge smile on my face. They had the Paralax setup next to it for five more dollars. I decided I was better off with the training wheels until I get the hang of this.
I just wanted to say thank you for adding those tutorials on youtube. That helped get me going. I managed to get through the switch and LED tutorials with mostly no issues other than the fact that I had no switches in the house that weren't being used. I'll have to pick some up. I just used a 100k pot and made believe it was a switch.image It worked well enough.
I have been hardware bashing on amplifiers, effects pedals and analog circuits for most of my life. I decided that my first Arduino will be used as a test bed for all the projects that I have been dreaming about for the last ten years. First thing. I need a CNC machine. I am so tired of all the extra work involved with etching my PCBs and I am more tired of waiting six months for the low rent houses to get around to it. This is where my first question comes in.
Is it possible for me to use the UNO for 3 axis control with the easy stepper drivers? From what I have been reading, it should be.
Second question. Is there a definative POV display library that is accepted or are most people just writing what seems to work? I am fairly certain I could get a basic 7 led display going. I have seen some crazy awesome stuff in that area but have found no real heavy discussion of how to add things like images and animation. My justification for spending money on this toy was showing my wife the videos of the POV clocks on youtube. I know I said the CNC was first but... I am not really the boss you see.
Thank you all again.
  • ntewinkel
    ntewinkel over 14 years ago +2
    Here's a neat POV harddrive clock, but it uses PIC. But with some POP (persistance of programmer ) it should be possible to port that to Arduino. http://www.ian.org/HD-Clock/
  • YT2095
    YT2095 over 14 years ago
    have a look at Sanguino, it`s based on an MCU that`s in effect, just a fat arduino image
    you`ll have no problem running 3 steppers with an arduino, esp if you have support driver chips to lower the code overheads.
    no idea about a dedicated POV.h file though.
  • ntewinkel
    Instructables has a handful of different DIY CNC how-to's that look really interesting. Oddly, I wasn't able to find out what they use (software/hardware) to control any of them yet - but then, I was just flipping through quickly. It almost looks like they just hook it straight up to an old computer.
    Here are a couple I thought looked very promising and high quality:
    wood: http://www.instructables.com/id/How-to-Make-a-Three-Axis-CNC-Machine-Cheaply-and-/
    all metal: http://www.instructables.com/id/DIY-CNC-Router/
    And a list of CNC how-to's: http://www.instructables.com/id/DIY-CNC/
    For the first wood one, if you have access to a CNC machine (at a college, maybe?), they have all the CNC files included to make the parts image
    Or it looks like you can buy a set of parts from these guys: www.makecnc.com
    You've made me realize that I'm long overdue for a CNC machine myself image
    And oddly enough, I can't find much on Persistance Of Vision for Arduino.
    Arduino.cc has a list of libraries they know about, which doesn't seem to include it: http://arduino.cc/playground/Main/InterfacingWithHardware
    But here is a little POV example for Arduino that seems to be based on the user having to shake the whole arduino+shield back and forth: http://www.instructables.com/id/Simple-POV-homemade-arduino-shield/
    I was hoping to find something I saw a long long time ago, involving something like a harddrive motor whipping a stick with LEDs on it around, but alas it has disappeared amongst all the other bits and bytes out there on the internet.
    Good luck with both of those projects!
    Cheers,
    -Nico
  • ntewinkel
    Here's a neat POV harddrive clock, but it uses PIC. But with some POP (persistance of programmer image) it should be possible to port that to Arduino.
  • fustini
    fustini over 14 years ago in reply to ntewinkel
    POP - I like it!
