Arduino Forum new to adruino
  • Subscribers 418 subscribers
  • Views 688 views
new to adruino
is there a way for the adruino to detect a certain voltage and react to it?
as in
input < 0.7volts = red light
input > 0.8volts = green light
would that be possible? i do not have an adruino board yet as i dont know which one would be capable of doing this. any input would be helpful thank you
  • l1t7l3ph0o7
    l1t7l3ph0o7 over 13 years ago
    All of the arduino boards are capable of doing this,
    There are lot's of tutorials about how to do it.
  • ntewinkel
    ntewinkel over 13 years ago
    Jory's being somewhat cryptic there, so I thought I'd post a direct link to a great tutorial that explains how to read varying voltage (0-5 volts) and shows you how:
    http://www.oomlout.com/oom.php/products/ardx/circ-08
    Oomlout has other tutorials on turning on LEDs if you need that, as well as several other useful and interesting projects you can try.
    Your mission is to determine what value the specific volts are at and then handle the LEDs.
    Cheers,
    -Nico
    If you go through all of Jeremy Blum's "Tutorials for Arduino" on YouTube you will have a very good understanding of all the things you can do with the platform.
    Try "Tutorial 04 for Arduino: Analog Inputs"
  • evan.stoddard
    evan.stoddard over 13 years ago
    Also in the arduino IDE, if you go to file>examples>basics the first item is analogreadvoltage.  If statements are pretty easy.  If you just take the voltages and place them in if statements then have the led turn on then your set.  Couple lines of code.  Follow the advice of others, do some googleing, look at make magazine (they do A LOT with arduinos) and just have fun image
