Arduino Forum my second switch statement.
  • Subscribers 417 subscribers
  • Views 544 views
I just wrote my first switch statemen and now Im working on the second but I cannot figure out why I get this error.  'states' was not declared in this case.  I am confused because it is just about the same as my first statement so why do I have this?
int state=8;
int mi=9;
int whichone;
int buttonst;
int buttonmi;
void setup()
Serial.begin(9600);
pinMode(state, INPUT);
pinMode(mi, INPUT);
buttonst=digitalRead(8);
buttonmi=digitalRead(9);
void loop()
switch(whichone)
  case 0:
  buttonst=HIGH;
  buttonmi=LOW;
  states();
  break;
  case 1:
  buttonst=LOW&&buttonmi=HIGH;
  mis();
  break
void states()
int states;
Serial.println("state");
delay (500);
void mis()
int mis;
Serial.println("mi");
delay (500);
  • mconners
    mconners over 13 years ago +1
    It looks like you have the function states() defined inside the function loop(). That last curly brace needs to be moved up above where you defined void states() good luck. Mike
  • billabott
    billabott over 13 years ago
    Appears to be illegal overloading of name "states"
    I'll bet it was flagged in the bottom window of the 'Duino IDE.
    This is what I do when I get those hard to read error messages in the bottom window:
    1. Left click mouse to select message of interest.
    2. Right click mouse to 'copy' the highlighted text.
    3. Open Notepad or any other word processor.
    4. Paste the text into Notepad and make the font size large enough to easily see.
    5. Use my brain power to syntactically analyze the error message.   Informally this is called parsing.  image
    6. If there is some phrase I have no idea about; then it helps to look that part up on the WWW.
    -=SyntaxMatters=-
  • mconners
    good luck.
    Mike
  • mconners
    mconners over 13 years ago in reply to mconners
    BTW, this is an error as well, buttonst=LOW&&buttonmi=HIGH;
    Not sure what you are trying to do there
  • mconners
    The following will compile, not sure it does what you want though.
    int state=8;
    int mi=9;
    int whichone;
    int buttonst;
    int buttonmi;
    void setup()
      Serial.begin(9600);
      pinMode(mi, INPUT);
    void loop()
      switch(whichone)
      case 0:
        buttonst=HIGH;
        buttonmi=LOW;
        states();
        break;
      case 1:
        buttonst=LOW;
        buttonmi=HIGH;
        mis();
        break;
    void states()
      int states;
      delay (500);
    void mis()
      int mis;
      delay (500);
