Arduino Forum How to do : pin1 + pin2 = Keyboard.press()
  • Subscribers 416 subscribers
  • Views 386 views
Hello.
Can anyone help me?
I have 32 buttons on 12 wires. It's done like this way: Button 1 is connected to wire1 and wire5. Button 2 is connected to wire1 and wire 5 etc...
Here is list of buttons and wires connected to buttons.
1 - 1;5
2 - 1;6
3 - 1;7
4 - 1;8
5 - 1;9
6 - 1;10
7 - 1;11
8 - 1;12
9 - 2;5
10 - 2;6
11 - 2;7
12 - 2;8
13 - 2;9
14 - 2;10
15 - 2;11
16 - 2;12
17 - 3;5
18 - 3;6
19 - 3;7
20 - 3;8
21 - 3;9
22 - 3;10
23 - 3;11
24 - 3;12
25 - 4;5
26 - 4;6
27 - 4;7
28 - 4;8
29 - 4;9
30 - 4;10
31 - 4;11
32 - 4;12
So I need connect these wires to arduino digital pins and I don't know how to program it. I need to do a Keyboard.press() function when is joined pin 1 and 5 etc.. Is there any solution of this?
Thank you in advance for your advice and answers.
Excuse my English. I'm from Czech Republic.
    e14 Contributor over 13 years ago in reply to ntewinkel +1
    Yeah. This is exactly what I needed. Thank you very much Nico
  • ntewinkel
    ntewinkel over 13 years ago
    I think you'd have to poll the first 4 lines and check for results on the other lines as you do so.
    This would be my approach:
    lines 1, 2, 3, 4 are Outputs.
    lines 5 to 12 are Inputs (connected to pulldown resistors)
    start with lines 1-4 set to Low.
    loop {
    -for lines 1-4:
    --put the line high, loop through lines 5-12 to see which one is high, and call keyPress() for the key that made it high.
    --return the line to low
    (maybe delay a few milliseconds here)
    You would probably want to use a 2D array of characters to easily keep track of which line combinations equal which key was pressed.
    edit: you'll also have to keep track of making sure a key press is only called once per physical press!
    Good luck!
    Cheers,
    -Nico
    Yeah.
    Thank you very much Nico image
  • ntewinkel
    ntewinkel over 13 years ago in reply to e14 Contributor
    Glad I could help image
    I just noticed this library, which I think pretty much does all the hard work for you: http://playground.arduino.cc/Main/KeypadTutorial
