    • Avnet Boards Community
Arduino Forum How can we use the Arduino or the Raspberry Pi as an integrated CAN or LIN BUS controler?
  • Subscribers 391 subscribers
  • Views 1607 views
toof2000
toof2000 over 12 years ago
  • dpushkashu
    dpushkashu over 10 years ago
    Hi. I do not know, if it is actual, but I found some interesting information on CAN-BUS interface with Arduino and I would like to share.
    1. CAN-BUS Shield http://www.seeedstudio.com/wiki/CAN-BUS_Shield
    There you can find  detailed information about this shield, including CAN-BUS Shield Schematic (.pdf and  eagle file), MCP2515 datasheet, MCP2551 datasheet.
    2. How to programming this sheild are described in detail in the following two articles
    CAN Prototyping with Arduino (http://bitstream24.com/can-prototyping-with-arduino/)
    CAN Prototyping with Arduino CAN-Bus Shield – Part 2 (http://bitstream24.com/can-prototyping-with-arduino-can-bus-shield-part-2/)
    Also, you may be interested in book
    Controller Area Network Prototyping with Arduino
    (http://www.amazon.com/Controller-Area-Network-Prototyping-Arduino/dp/1938581164/ref=pd_sim_sbs_b_2?ie=UTF8&refRID=0HKCJ9SCQ3JSN3CTFQN6)
    Good luck in your project.
    documentation-113030021.zip
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago
    using a chip like this http://ww1.microchip.com/downloads/en/DeviceDoc/21801G.pdf can allow you to integrate either an Arduino or a pI to the CAN bus, I have just posted the first in a series of videos on interfacting the PI to various chips using SPI and or I2C, this chip will be no harder to integrate than those from a hardware and basic software perspective, you will of couse need to learn the CAN protocol coding etc but this will help get the hardware up and running. couple this with information you can get from the links provided by dpushkashu and youll be well on your way
    here is my video
    Hope it helps
    michaelkellett over 10 years ago
    You need to explain much better what you are trying to do - as has been pointed out it isn't that hard to add a CAN controller chip of some kind to an Arduino or RPI - but that is only the start of the story - you need to tell us what your integrated controller is supposed to be doing before a reasonable recommendation can be made.
