Arduino Forum Driver for the 60mm & 48mm RGB LED matrix
  • Subscribers 415 subscribers
  • Views 169 views
  • matrix
  • led
  • shield
Rainbow Shield in Elecrow available now!
This Rainbow Shield is used to drive the LEDs components, such as the 8x8 RGB matrix or the seeed rainbow cubes. With the help of Arduino/Crowduino, this shield can driver a max of 192 single color LEDs, or 64 RGB LEDs. it uses two MY9221 chips, which is 12-channels (R/G/B x 4) constant current Adaptive Pulse Density Modulation(APDM), and with the professional multiplexed LED driver library and the related power supply circuit. you can cascade more such boards with 8 power supply, 3 signal line and 1 GND. and easily control your LED squares to create your idea patterns.
Driver the 60mm RGB MatrixDriver the 48mm RGB Matrix
For more detail, please visit Elecrow - Rainbow Shield.
