Arduino Forum robotic wheel chair help
  • Replies 30 replies
  • Subscribers 420 subscribers
  • Views 3267 views
can some one help me with robotic wheel chair using arduino uno
    michaelkellett over 12 years ago in reply to rajiv.tctech +1
    The ESP article is OK as far as it goes but it's really only concerned with simple mains power supplies. It has a tiny section at the end about switching supplies but it's way out of date. The wheelchair…
  • alanwood
    alanwood over 12 years ago in reply to e14 Contributor +1
    Hi Prajwal, This is supposed to be your project not ours. If you keep asking questions and expecting answers, you will never learn how to be an engineer. That is why you are training, isn't it? I'm sorry…
  • vsluiter
    vsluiter over 12 years ago
    Hello Prajwal,  That question is a bit too general I'm afraid. Do you already have a wheel chair? Does it already have motors? Do those motors have drivers (like: boxes that take power and control, to drive the motor)? If  yes, do you know how those work?  If you report that, we could give you some directions on where to start reading next.  Victor
    e14 Contributor over 12 years ago in reply to vsluiter
    thank you victor for replying.
    actually we are building this as our college project.we have thought of using DC motors and 2 axis joystick for conrtolling the directions.actually we don't what device drivers are!! where to use.:(
  • vsluiter
    vsluiter over 12 years ago in reply to e14 Contributor
    Good to start with DC motors, but developing your own motor drivers (power amplifiers) might be a lot of work... If you want to build something small (like a scale model) you could use the motor shield of Arduino or from Adafruit, both also have libraries that show you how to drive the motors.
    we are using h bridge. wat is the main use of it. can u tell pls.:)
  • vsluiter
    http://en.wikipedia.org/wiki/H_bridge
    i understood what is device drivers but i didn't get whether it is a hard ware component or we have to write the code for it.
    help me pls...
  • vsluiter
    'Motor Driver' is a more general term for a hardware component that is mostly built up out of one or more H-bridges.
    can u pls tell me how to interface joystick and call routine program of the motor.
  • vsluiter
    This is your college project; I think it would be wise to first read some information on electronics and on, Arduino. Do some test projects with switches, potmeters and ontrol some LEDs before turning on a robotic wheel chair.
    Good luck in trying things out!
    can u pls tell me what value of capacitor must be used for connecting external supply to H bridge for driving 12V dc motor..pls
