Arduino Forum Ok, pathetic Newbie needs 7 segment help
  • Subscribers 417 subscribers
  • Views 426 views
  • multiplexing
  • 3_digit
  • 7_segment
  • display
funinalaska
funinalaska over 12 years ago
I am looking for a tutorial on 7 segments.
I am looking for something that will help me with a multiplex 3 digit 7 segment display.
The final reason for this is a simple temperature display, But I also want to learn how to use 7 segments and multiplexing a little better.
I have the things I need to do it, I am using the pins on my arduino for the anode pins (8 of them) I have 3 NPN transistors for the cathodes
I have gone through a tutorial on using a single digit display that does a basic countdown.
I would like something similar but that shows how the multiplexing aspect works and that I will be able to figure out how to adapt for a useful display.
I got 4 single digit displays, I was debating putting the 4th on but I decided against it based on the temperatures we see here are usually only 2 digit or negative 2 digit.
I am not concerned about any finer accuracy than whole digits so no need for decimals.
Anyway, if anyone knows of a tutorial somewhere online I can use to get me started I would greatly appreciate it.
Most of the ones I have found use either 595 shift registers or MAX plexing chips.
I would like to avoid these things for now so I can understand the basics.
  • johnbeetem
    johnbeetem over 12 years ago
    Wikipedia is a good place to start, with some useful links.  At Atmel app note AVR242 referenced in the Wikipedia article shows how to wire up a common anode display with PNP drivers at the top for each digit.  A common cathode display is basically the same, with NPN drivers at the bottom for each digit.
  • funinalaska
    funinalaska over 12 years ago in reply to johnbeetem
    I got the how to wire it up it is mainly the coding I am having issues with.
    Is there a library made for 7 segment multiplexing?
    How do I tell the arduino about refresh rates and how many digits, what number I want on each digit and things like that?
  • johnbeetem
    johnbeetem over 12 years ago in reply to funinalaska
    I've never programmed Arduino and don't know if there are libraries available.  The AVR242 app note referenced by Wikipedia (http://www.atmel.com/dyn/resources/prod_documents/doc1231.pdf) has flowcharts and other documentation for multiplexing, along with AVR assembly language.  There must be Arduino examples somewhere for things like interval timing.  Converting a number to BCD digits and looking up the seven-segment patterns for those digits in a small array of bytes should be simple, especially in C.
