Arduino Forum First adriuno project made
  • Replies 14 replies
  • Subscribers 418 subscribers
  • Views 1370 views
I made my very first Ardiino project on Saturday 4th January 2014 - a 10 LED chaser (like the one seen in Knight Rider)!
    e14 Contributor over 12 years ago in reply to saurocksall +1
    I am gong to attempt multiplexing with 74hc595's to control more LEDs in a LED chaser
    e14 Contributor over 12 years ago +1
    Hi, Try using this LED matrix to create something with it (for example a game or a screen). Practicing with it would help you a lot with Arduino. LED Matrix (8 x 8 Bi-Colour) – oomlout Good luck. A.A
    e14 Contributor over 12 years ago in reply to e14 Contributor +1
    I am trying 16 LEDs in a 4x4 matrix, the first time I wired my board , it didn't work properly - then I noticed I wired the LEDs wiring wrong - so gonna alter it!
    Hi Peter,
    Could you please explain why you will use 4 shift registers to control 32 LEDs? In the project I did, I controlled 64 LEDs with only 2! I think there might be a more efficient way to control the LEDs with less SRs, unless the LEDs matrix is connected in a weird way. I noticed that the Arduino you are using is different to the one I used, that might be the case, but I am not sure though.
    Good luck
    A.A
    I Had some trouble wiring LEDs in a matrix , so I decided to try multiple shift registers to control the same idea (ie 16 or 32 LEDs in a row)
    Might practice with matrix/s till I get the hang of it
    Well, i started my Arduino journey with basic LED blink project image and now i have done a lot of projects...i also intend to teach Arduino with my tutorials...you can find those tutoials her at the given link...hope this is helpful for you to learn!
    http://www.zseries.in/embedded%20lab/arduino/
  • neilk
    neilk over 12 years ago in reply to e14 Contributor
    @ Sapien Humanoid
    Your collection of tutorials, based on your Arduino journey looks excellent. Thanks for posting them.
    Neil
