Arduino Forum Problem using while statement. Please help
  • Subscribers 416 subscribers
  • Views 225 views
I am receiving a signal from ir receiver based on the receiver value, I am using a function in void loop(). In this function I am again receiving ir value and using switch statement to direct it to a case. Within that case I am using while statement (I am again receiving ir values) to run this function for two minutes. But the statements within the while statements are not running. Please help what I am doing wrong. My program is as follows.
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
#include <IRremote.h>
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *myMotor1 = AFMS.getMotor(1);
Adafruit_DCMotor *myMotor2 = AFMS.getMotor(2);
Adafruit_DCMotor *myMotor3 = AFMS.getMotor(3);
Adafruit_DCMotor *myMotor4 = AFMS.getMotor(4);
// You can also make another motor on port M2
//Adafruit_DCMotor *myOtherMotor = AFMS.getMotor(2);
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
  Serial.begin(9600);
  irrecv.enableIRIn(); // Start the receiver
  AFMS.begin();  // create with the default frequency 1.6KHz
//AFMS.begin(1000);  // OR with a different frequency, say 1KHz
  if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
void loop()
  if (irrecv.decode(&results)) // have we received an IR signal?
    translateIR2();
    irrecv.resume();
void translateIR2() {
switch(results.value)
    case 0x21:
      unsigned long sec;
      unsigned long A;
      A=millis();
      while(sec < 120000){
       // Statements…;
sec=millis()-A;
Serial.println(sec,HEX);
        break;
      default:
Serial.println(" other button ");
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    When you call translateIR2(), don't call irrecv.decode(&results) again, you have already pulled the received code from the library, and may not get another so remove the line and the IF statement that…
    When you call translateIR2(), don't call irrecv.decode(&results) again, you have already pulled the received code from the library, and may not get another so remove the line and the IF statement that goes with it
    That may well fix the problem
    Regards
    Peter
