Arduino Forum Arduino - Ethernet module pin out, diffent model/renamed pins ? (missing SI pin)
  • Subscribers 402 subscribers
  • Views 550 views
  • hanrun
  • ethernet
  • hr911105a
This module has 6 pins.
I should only be using a few of them,,,  mainly
5v - GND - CS - SCK - SI and SO, and possible RST to GND
That's atleast what the guides say, however this module is missing the SI,
ofcourse i know it's there, but it's running under a different name, but which ?
    I think i got it,   the SI replacement is actually ST,,  not sure what the T represents...
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to Former Member
    and if you want to be really sure, it should connect to the SI pin (7)  of the enc28j60 chip
    Former Member over 11 years ago in reply to Robert Peter Oakes
    Thx Peter.
    With the schematic and my multimeter i was able to confirm the pin is in fact ST..
    I downloaded an external library from git hub called "ethercard.h"  and my arduino is now online as a server..
    works like a charm..
    Funny thing though, the default Ethernet libraries don't work, and always end up with server at 0.0.0.0 error.
    While the external library works right out of the box with the included examples.
    The default libraries are for the WIZNET Ethernet chip (The one the original Arduino Ethernet Shield), not the ENC28J60 on the card you have, the newest libraries are 100% sketch code compatible but you still need to ensure you use the right one
    I think my tutorials lesson 4 or 5 talks about this and shows an example of using them and hosting web pages
    Peter
    What is this module? Available as current product from anyone at this time? Price? Thanks.
    Former Member over 11 years ago in reply to Former Member
    Search on Ebay or your other favorite auction online site for "arduino ethernet module"
    and a ton of these will show up, ofcourse they are marked in the text usually with ENC28J60..
    I just did a search and the first 5 posts on ebay show up at 2-3$ each.
