Arduino Forum pins 12 , 13
  • Subscribers 419 subscribers
  • Views 461 views
pins 12 , 13
are pins 12, 13 the only pins that can drive "hi" an led.... very new to this and trying to get all pins hi to drive leds, like a parallax
    jw0752 over 11 years ago
    Hi John, As long as you set the pin as an OUTPUT you can digitalWrite any pin 0 to 13 HIGH or LOW.
    mcb1 over 11 years ago in reply to jw0752
    John and John
    You are correct, however I generally caution people against using pins 0 and 1 since they are the Atmega328 Rx and Tx, and can cause issues.
    You can also use the Analogue inputs as normal I/O so A0, 1, 2, 3, 4, 5 = Pin 14, 15, 16, 17, 18, 19 and can be set as an input or output.
    thank you.........  sometimes its just the little things........ thank you
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to mcb1
    And many of the pins can also be used as PWM output in hardware, look for the "~" on some of the pins on an official Arduino to see which pins, or look at the arduino site for the pin definitions
    Peter
