Arduino Forum Arduino MQTT client with QoS1 and 2
  • Replies 7 replies
  • Subscribers 417 subscribers
  • Views 2257 views
  • mqtt
I got MQTT client for Arduino from "http://knolleary.net/arduino-client-for-mqtt/".But this seems to have only QoS0.
Do we have any upgraded version of Arduino MQTT client with QoS1 and 2.Is it possible to have QoS1 and 2 for MQTT publish and subscribe in Arduino?
    e14 Contributor over 11 years ago in reply to lokkytron +1
    Wow..Thanks a lot lokkytron .Will check that..
    No problem..Thanks for your help..I will also wait for other experts advice on this..
  • lokkytron
    lokkytron over 11 years ago
    Hello Radhamani Ramadoss.
    In comment 99 at the same page you got it:
    These are not in the plan for this client as there is no reliable storage on the arduino, so we cannot provide proper QoS 1 or 2 semantics.
    This seems to me a reason to do not use QoS1 or QoS2 with arduino.
    Ok..I saw that..
    But the thing is,we prefer MQTT over HTTP because it provides guaranteed delivery with Qos1 and 2.When that is not possible with Arduino,then why we need to go for MQTT in Arduino?I am not sure what is the benefit of using MQTT with Arduino..
    Please let me know..
  • lokkytron
    Radhamani Ramadoss, I found this post in which Mark Cheverton
    tells how it has been added QoS1 to the same library you are using , and Mark gives details on how to set up this level of QoS
    I am so noob at this moment with all the Arduino stuff (hard and soft) to enter to discuss deeper about this protocol, but I hope this helps.
    Wow..Thanks a lot lokkytron.Will check that..
    e14 Contributor over 11 years ago in reply to e14 Contributor
    I just checked...But I could not get the code with Qos1 updated in MQTT client library.
  • lokkytron
    lokkytron over 11 years ago in reply to e14 Contributor
    I am sorry to read that.
    As i said for now i have no experience and I can not go deeper in MQTT than search through the web to try to help you.
