Arduino Forum Code help please. Arduino Uno / velleman VMA05 controlling relays and rgb light for external 12V systems in vehicle.
  • Replies 10 replies
  • Subscribers 415 subscribers
  • Views 969 views
  • code
  • help!
Hi
I have been desperatly trying to write a code that i felt would be simple but i am unable to finish it.
I want to control the VMA05 relays with individual buttons in a toggle fashion with momentane pushbuttons. Six relays and six buttons. i also want a specific behavior of several RGB lights to indicate open or closed relay by switching from green to blue when activated and back when deactivated by a second press.
i have been trying several variants of code just stumbling around but i want the setup to be closely like this (in assumed function) I apreachiate any and all help, a dream would be if someone really smart could fix this code for me. The arduino board will be used to control systems for a vehicle used in Swedish volonteer mountain rescue situations as well as other live scenarios (which due to the lack of budget explains the use of arduino)
const int BTN1 =7;
int press1 =0;
const int BTN2 = 6;
int press2 =0;
const int BTN3 = 5;
int press3 =0;
const int BTN4 = 4;
int press4 =0;
const int BTN5 = 3;
int press5 =0;
const int BTN6 = 2;
int press6 =0;
int relay1 =8;
int relay2 =9;
int relay3 =10;
int relay4 =11;
int relay5 =12;
int relay6 =13;
void setup()
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(7, INPUT);
  pinMode(6, INPUT);
  pinMode(5, INPUT);
  pinMode(4, INPUT);
  pinMode(3, INPUT);
  pinMode(2, INPUT);
void loop()
  press1 = digitalRead(BTN1);
  if (press1 == HIGH && relay1 == LOW )
   (relay1, HIGH);
  }else
   (relay1, LOW);
    press2 = digitalRead(BTN2);
  if (press2 == HIGH && relay2 == LOW )
   (relay2, HIGH);
  }else
   (relay2, LOW);
    press3 = digitalRead(BTN3);
  if (press3 == HIGH && relay3 == LOW )
   (relay3, HIGH);
  }else
   (relay3, LOW);
    press4 = digitalRead(BTN4);
  if (press4 == HIGH && relay4 == LOW )
   (relay4, HIGH);
  }else
   (relay4, LOW);
    press5 = digitalRead(BTN5);
  if (press5 == HIGH && relay5 == LOW )
   (relay5, HIGH);
  }else
   (relay5, LOW);
    press6 = digitalRead(BTN6);
  if (press6 == HIGH && relay6 == LOW )
   (relay6, HIGH);
  }else
   (relay6, LOW);
  • gadget.iom
    0 gadget.iom over 11 years ago
    Hi
    Looking at your code it would appear that it is working, but not as you expected, because the program is looping so fast that pressing the button will result in an on statement and an off statement almost immediately.
    Take a look at the following code, taking into account the use of the "previous" variable and incorporate this into your design.
    https://www.arduino.cc/en/Tutorial/Switch
    You could basically replicate this code 6 times and add a number to these variables.
    Does this make sense?
    Paul
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    Hello and thankyou for your reply
    I actually found this specific tutorial and gave it a try. I failed however, i tried this without result.
    I dont know where to add the relay HIGH... As i want a on off toggle effect with the same momentane button i am at a loss. So you see my mistake?
    int inPin1 = 2;
    int inPin2 = 3;
    int inPin3 = 4;
    int inPin4 = 5;
    int outPin1 = 13;
    int outPin2 = 12;
    int outPin3 = 11;
    int outPin4 = 10;
    int state = HIGH;      // the current state of the output pin
    int reading1;
    int reading2;
    int reading3;
    int reading4;          // the current reading from the input pin
    int previous = LOW;    // the previous reading from the input pin
    // the follow variables are long's because the time, measured in miliseconds,
    // will quickly become a bigger number than can be stored in an int.
    long time = 0;         // the last time the output pin was toggled
    long debounce = 200;   // the debounce time, increase if the output flickers
    void setup()
      pinMode(inPin1, INPUT);
      pinMode(inPin2, INPUT);
      pinMode(inPin3, INPUT);
      pinMode(inPin4, INPUT);
      pinMode(outPin1, OUTPUT);
      pinMode(outPin2, OUTPUT);
      pinMode(outPin3, OUTPUT);
      pinMode(outPin4, OUTPUT);
    void loop()
      reading1 = digitalRead(inPin1);
      // if the input just went from LOW and HIGH and we've waited long enough
      // to ignore any noise on the circuit, toggle the output pin and remember
      // the time
      if (reading1 == HIGH && previous == LOW && millis() - time > debounce) {
        if (state == HIGH)
          state = LOW;
        else
          state = HIGH;
        time = millis();
      reading2 = digitalRead(inPin2);
      if (reading2 == HIGH && previous == LOW && millis() - time > debounce) {
        if (state == HIGH)
          state = LOW;
        else
          state = HIGH;
        time = millis();
      {  reading3 = digitalRead(inPin3);
      if (reading3 == HIGH && previous == LOW && millis() - time > debounce) {
        if (state == HIGH)
          state = LOW;
        else
          state = HIGH;
        time = millis();
      {reading4 = digitalRead(inPin4);
      if (reading4 == HIGH && previous == LOW && millis() - time > debounce) {
        if (state == HIGH)
          state = LOW;
        else
          state = HIGH;
        time = millis();
      digitalWrite(outPin1, state);
      digitalWrite(outPin2, state);
      digitalWrite(outPin3, state);
      digitalWrite(outPin4, state);
      previous = reading1;
      previous = reading2;
      previous = reading3;
      previous = reading4;
    0 autodeskguest over 11 years ago in reply to e14 Contributor
    mistake?
    One of your mistakes is that you've posted this in the wrong place. This
    is a discussion group for the Cadsoft Eagle PCB design tool. You'd get
    better answers in a programming related forum.
    That said, if you want a toggle action, you must ignore the button being
    held and only toggle when it's first pressed. The basic code will be:
    if ( input==HIGH && old_input==LOW )     // Only act on leading edges
        output = ! output;          // toggle the output
        old_input = input;          // remember the state for edge detect
    I'll leave the incorporation of this principle, including the fixing of
    the glaring bug, as an exercise for the reader.
    0 e14 Contributor over 11 years ago in reply to autodeskguest
    Hi
    Oh sorry i did not realize, found my way here through some weird arduino google search and gave it a try.
    thank you for your help but as i am not a programmer this is a bit beyond me and since i need to make the code work just once i dont feel i have the time to learn programming for this one instance, but i greatly appreciate your efforts!
    I will try to make sense of this and keep searching for a more programming related page.
    Thankyou //Thor
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to e14 Contributor
    You have posted this in on an ENTIRELY appropriate website. Just in the wrong area.
    I will ask element14jamie or element14support to move this topic to a more appropriate area.
    Maybe Arduino.
    From there we can help you further.
  • element14jamie
    0 element14jamie over 11 years ago in reply to gadget.iom
    Hello gadget.iom
    Thank you, I have moved it.
    Thank you again,
    Jamie
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to element14jamie
    Cheers element14jamie
  • gadget.iom
    Hi Thorgeir
    Hopefully you are still with us. We are now "In the Zone".
    Lets start simple and make this work for one relay first ok?
    int btn1 = 2;         // the number of the button 1 pin
    int relay1 = 13;       // the number of the relay 1 pin
    int state1 = LOW;      // the current state of the relay 1 pin
    int reading1;           // the current reading from the button 1 pin
    int previous1 = LOW;    // the previous reading from the button 1 pin
    void setup() {
      pinMode(btn1, INPUT);
      pinMode(relay1, OUTPUT);
    void loop() {
      reading1 = digitalRead(btn1);
      // the time
      if (reading1 == HIGH && previous1 == LOW && millis() - time > debounce) {
        if (state1 == HIGH)
          state1 = LOW;
        else
          state1 = HIGH;
        time = millis();
      digitalWrite(relay1, state1);
      previous1 = reading1;
    Thank you very much image It is toggling just fine.
    Just a bit of tinkering to get the other relays up to par then.
  • gadget.iom
    Hopefully. image
    Let us know how you get on.
    Paul
