Arduino Forum Stepper motor wiring help(and a few other small questions from an instructable)
  • Replies 55 replies
  • Subscribers 420 subscribers
  • Views 7003 views
  • wiring
  • steppers
gub11
gub11 over 10 years ago
This instructable really interested me, Frameless Laser Harp - 4 , but i've never worked with steppers before.  the stepper i got has 4 wires, but the stepper in the instructable has 6.  on page 2 there is a wiring guide, but that wasn't very helpful to me, i didn't really understand what i'm supposed to do with the wires.  This is the stepper i have, https://www.sparkfun.com/products/10551?gclid=Cj0KEQiApruyBRCFqoDu1pbk9rkBEiQAF8EFdVmEBorGt6koPmFkaibEpRmZ94Z6r8BWhmTqAL… .  Any ideas?
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to gub11 +2 suggested
    reverse... to change direction lol now more seriously... then you wire up the stepper motor, if it is not going in the direction you expect for the command your giving then you can change the code or simply…
    Robert Peter Oakes over 10 years ago +1
    Here is an excelent resource regarding steppers and how they work http://www.geckodrive.com/support.html I found this to be very helpfull in setting up my CNC project your stepper is a classic 4 wire …
    Robert Peter Oakes over 10 years ago in reply to gub11 +1
    All Grounds (0V) should go together, the ground of the 12V, the 5V etc all are connected together at a common point the 5V goes to all those pins because it is 5V logic input to the chip and those pins…
    0 Robert Peter Oakes over 10 years ago in reply to gub11
    There all about the CNC Project, if you simply go to https://youtube.com/c/thebreadboardca and look at the video list it may be easier to understand as the descriptions are there along with suitable images
    btw, the video is almost completed uploading and will be available in a few minutes https://youtu.be/pSJQWe5iGn0
    I will post a formal blog entry tomorow with code and everything and embed the video
    for now, here is the final code so you can try it and let me know if it works
    Enjoy
    #include <Stepper.h>
    const int stepsPerRevolution = 48;  // change this to fit the number of steps per revolution
    // for your motor
    // initialize the stepper library on pins 8 through 11:
    int motorPinA = 8;                      //Winding A.
    int motorPina = 9;                      //Winding a.
    int motorPinB = 10;                     //Winding B.
    int motorPinb = 11;                     //Winding b.
    int rpms = 300;                         // Revolutions per minute  for stepper 300/60 = 5 revs per second = 240 steps per second = about 25 scans per second
    Stepper myStepper(stepsPerRevolution, motorPinA, motorPina, motorPinB, motorPinb);
    int StepSize = 1;
    int LaserState = LOW;                    // The variable that stores the state of the laser beam.
    int sensor = 8 ;                         // Change this value to calibrate your harp's sensor
    int delaylaser = 3;                     // If you increase this, the laser will be brighter, but the harp will be less fluid
    int delaymotor = 3;                     // This variable affects the speed, and fluidity of the harp.
    int LaserPin =  7;                       // Tell the arduino that the laser is on pin 7
    int notes[] = {0x47, 0x40, 0x71, 0x70, 0x68, 0x66, 0x64, 0x53, 0x61 };
    int notesState[] = {0x0, 0x00, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0 };
    int arraySize = sizeof( notes )/ sizeof( notes[0]);
    int cmd = 0x90;
    int VelocityOn = 0x7F;
    int VelocityOff = 0x00;
    void setup()
      pinMode(LaserPin, OUTPUT);            // Setup for laser.
      pinMode(13, OUTPUT);                 // Setup for status led.
      Serial.begin(31250);                 //  Start a serial communication channel for MIDI
      myStepper.setSpeed(rpms);
    void loop()
      // we will do note 0 to keep things consistant at th end of the loop
      //SenseLaser(0)                               // note 1 (Array is zero based)
    for (int counter = 0 ; counter < arraySize ; counter++)
      myStepper.step(1);                          // Step the stepper ++
      //delay(delaymotor);                          // Small pause, may not be needed ??
      SenseLaser(counter);                        // note counter
    for (int counter = arraySize-1 ; counter >= 0  ; counter--)
      myStepper.step(-1);                          // Step the stepper ++
      //delay(delaymotor);                          // Small pause, may not be needed now
      // Back to top.
    void SenseLaser(int index)
      digitalWrite(LaserPin, HIGH);               // Turn on the laser for the 1st beam.
      delay(delaylaser);
      if (analogRead(0) > sensor )
        noteOn(index);
      else if (analogRead(0) < sensor )            // If the sensor does not get a signal:
        noteOff(index);
      digitalWrite(LaserPin, LOW);                // Turn off the Laser.
    void noteOn( int pitchindex)     // Function to play the notes
      if (  notesState[pitchindex] == 0) // If the sensor gets a signal, and the not is not playing:
        Serial.write(cmd);
        Serial.write(notes[pitchindex]);
        Serial.write(VelocityOn);
        notesState[pitchindex]++;                          // Change the status variable to one.
        digitalWrite(13, HIGH);       // Switch on status led.
    void noteOff( int pitchindex)     // Function to play the notes
      if (  notesState[pitchindex] > 0) // If the sensor does not get a signal, and the not is playing:
      Serial.write(cmd);
      Serial.write(VelocityOff);
      notesState[pitchindex] = 0;                        // Change the status variable to 0.
      digitalWrite(13, LOW);       // Switch off status led.
  • gub11
    0 gub11 over 10 years ago in reply to Robert Peter Oakes
    Robert Peter Oakes
    The Code runs, but I'm having the same issue, the stepper is stepping, but with long pauses in between steps.
    try putting this parameter to a smaller value like 50 or something
    int rpms = 300;
    this may see if the stepper is simply not fast enough, I dont have the chip or a stepper like yours to try so cant verify that
    I have plenty of large steppers but again, not he same as yours
    If you slow down the steps using the above parameter enough, you could place LEDs on the output of the arduino and ensure the sequence ir sight, I did that here and it looks good to me, You can also check the stepper connection from the chip to stepper with a DMM and verify the voltages are changing are of a correct value.  If you have two DMMs then you can verify the actual sequence is correct to the stepper windngs and that the voltages are reversing etc.
    outside of that, im not sure what else I can do as you have verified you wiring, the code now is correct as best I can see so unless your chip is getting really hot for some reason, it should be working
    Regards
    Peter
    0 Robert Peter Oakes over 10 years ago in reply to Robert Peter Oakes
    Ah, one thing I forgot to also mention and it may be important. ( I am so used to them being there I completly missed the fact they were not there)
    Decoupling capacitors on the supply rails near the chip for both the +5V and the 12V.
    I dont see any on your board and there essential for reliable operation
    looking at this circuit from TI it clearly shows them, and the value required
  • gub11
    I'll test that out when I get home, i think i have two .1μF at my bench from something else, so that's convenient.  If it helps, here is the datasheet for my stepper  http://cdn.sparkfun.com/datasheets/Robotics/ST-PM35-15-11C.pdf .  What do the capacitors do in this case, I mean I know what capacitors do in general, but why would they make a difference here?
  • gub11
    Robert Peter Oakes
    The capacitors I have at home are ceramic caps.  Would these work? HQ 1uF 50V Aluminum Radial Electrolytic Decoupling Capacitors Pack of 20 | eBay
  • gub11
    0 gub11 over 10 years ago in reply to gub11
    Robert Peter Oakes
    Those should work for the 1μF caps, but I can't find any .1μF decoupling caps, could you link me some?
    yup, should be good
    try finding some 100nF instead, you should find thouse and they will do instead of the 0.1uF
  • gub11
    Robert Peter Oakes
    I can't find any of those either, maybe i'm being too specific.  can u send me a link?
