Arduino Forum Stepper motor wiring help(and a few other small questions from an instructable)
  • Replies 55 replies
  • Subscribers 420 subscribers
  • Views 7002 views
  • wiring
  • steppers
gub11
gub11 over 10 years ago
This instructable really interested me, Frameless Laser Harp - 4 , but i've never worked with steppers before.  the stepper i got has 4 wires, but the stepper in the instructable has 6.  on page 2 there is a wiring guide, but that wasn't very helpful to me, i didn't really understand what i'm supposed to do with the wires.  This is the stepper i have, https://www.sparkfun.com/products/10551?gclid=Cj0KEQiApruyBRCFqoDu1pbk9rkBEiQAF8EFdVmEBorGt6koPmFkaibEpRmZ94Z6r8BWhmTqAL… .  Any ideas?
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to gub11 +2 suggested
    reverse... to change direction lol now more seriously... then you wire up the stepper motor, if it is not going in the direction you expect for the command your giving then you can change the code or simply…
    Robert Peter Oakes over 10 years ago +1
    Here is an excelent resource regarding steppers and how they work http://www.geckodrive.com/support.html I found this to be very helpfull in setting up my CNC project your stepper is a classic 4 wire …
    Robert Peter Oakes over 10 years ago in reply to gub11 +1
    All Grounds (0V) should go together, the ground of the 12V, the 5V etc all are connected together at a common point the 5V goes to all those pins because it is 5V logic input to the chip and those pins…
  • gub11
    0 gub11 over 10 years ago in reply to gub11
    forgot to do the Robert Peter Oakes
    0 mcb1 over 10 years ago in reply to Robert Peter Oakes
    I'm thinking there is a distinct lack of decoupling caps along with some meaty Filter caps.
    I suspect that removing the power to the common of the stepper (or adding a series resistor) stops the issues.
  • gub11
    0 gub11 over 10 years ago in reply to mcb1
    mcb1 could you please explain a bit more, possibly with a diagram?
    0 mcb1 over 10 years ago in reply to gub11
    Sorry I'm busy with work and no internet at home.
    You could always try this link
    https://www.google.com/#q=decoupling+caps
    Peter is handling it and the comment was made to him as a possible difference.
    0 Robert Peter Oakes over 10 years ago
    I am currently putting together a complete tutorial ish video to explain how to convert from the Harp based on unipolar stepper (Not very well driven) to a Bipolar Stepper Driven correctly and massivly simplified code to go with it... standby image
  • gub11
    0 gub11 over 10 years ago in reply to Robert Peter Oakes
    Ok, Thanks a lot for helping so much!  eta?
    0 Robert Peter Oakes over 10 years ago in reply to gub11
    rendering now, its about 50mins long after editing but I think you will be amazed how shorter the code is and how simpler it is. I dont have your stepper driver but I tested it on an oscilloscope to validate the timeing and its all working well for the laser and the steps output atleast, you should be able to simply upload the code and go
    The video is detailed and I explain most of what I found and changed and why
  • gub11
    Thanks a lot man, I didn't expect somebody to go so far as to create a tutorial for me
    Not just for you but I used your project as the topic, its for everyone and it fits with my major project (One of them) which is a CNC Tutorial Build, you can find it here:-
    https://www.youtube.com/watch?v=gt9KB4Szbao
    https://www.youtube.com/watch?v=lCMRylhuWjM
    https://www.youtube.com/watch?v=l1uCW46pxK4
    https://www.youtube.com/watch?v=dgkmq3th3ho
    https://www.youtube.com/watch?v=PtuHbTg4_z0
    https://www.youtube.com/watch?v=qvQ00WmZTuU
    https://www.youtube.com/watch?v=gA4U8f9Tb14
    and there is loads more to come
  • gub11
    Robert Peter Oakes
    Which one pertains to my situation?
