Arduino Forum Arduino led on and off program using hc05 bluetooth module doesn't work.
  • Subscribers 406 subscribers
  • Views 1272 views
  • bluetooth
  • arduino uno
  • hc05
  • hc-05
Former Member over 9 years ago
I have tried to connect my arduino with hc-05, and run a simple 'LED on and off' program. When I disconnected the rx and tx pins and tried sending the commands using serial monitor in arduino, and it worked perfectly alright. But when I connected the rx and tx pins of hc-05 bluetooth module, and used the Bluetooth terminal app from playstore to send and recieve commands, whatever I send doesn't get recieved the same, instead I get weird characters on my serial monitor. Someone please help me solve this. I have included the arduino code and the screen shots of the serial monitor and the app.
char junk;
String inputString="";
void setup()
Serial.begin(9600);
pinMode(13, OUTPUT);
void loop()
  if(Serial.available()){
  while(Serial.available())
  char inChar = (char)Serial.read();
  inputString += inChar;
  Serial.println(inputString);
  while (Serial.available() > 0)
  { junk = Serial.read() ; }
  if(inputString == "a"){
  digitalWrite(13, HIGH);
  }else if(inputString == "b"){
  digitalWrite(13, LOW);
  inputString = "";
Serial Monitor
Bluetooth terminal App
  • gihu
    0 gihu over 9 years ago
    It seems like if Arduino and HC05 were configured with different baudrate.
    Check both UART work at the same baudrate, with the same parity, stopbits...
    Hope that helps
  • neilk
    0 neilk over 9 years ago
    hi venkatpraveenx
    Your Arduino and HC05 appear to be on different baud rates. Look at the configuration of the HC05 - it should be 9600
    Neil
  • clem57
    0 clem57 over 9 years ago
    Check if the terminal program in Arduino is using character return and line feed or not. If ob, turn off.
    Clem
