Arduino Forum What is the afforadable and acurate way to decode 433mhz wireless data ?
  • Replies 27 replies
  • Answers 6 answers
  • Subscribers 419 subscribers
  • Views 7135 views
  • signal
  • decoding
  • wireless signal decoding
  • radio
  • 433 mhz
  • paquet sniffer
  • wireless
  • remote
  • rf scanner
  • decoder
  • frequency
redgreenblue
redgreenblue over 9 years ago
Simply looking for a way to capture, copy and then trigger wireless data from an arduino.  I wish to get all the wireless devices in my home to be control from a single remote, so I need a scanner that would give me all the data, right now it give me more headache than data.
1- I've google ''Packet Sniffer'' and found the Texas Instruments SmartRF but the module is over 500$, which is pricy for me since I would do this only ONCE.
2-  I've spend quite lot of time trying to get signal from my Garage Door opener with and arduino and RF module, but the information capture is NOT ACCURATE.
(*seem like the arduino RF library can't do an accurate work or the Receiver not compatible with some remote I have)
So is there another way ?
Someting more simple and accurate.
Thanks for any suggestions, help or comments.
  • kas.lewis
    kas.lewis over 9 years ago +1 suggested
    What you are essentially trying to do with your current setup is to use a generic postcard reader and want to understand what the postcard says but your forget that there are different languages around…
  • neilk
    neilk over 9 years ago +1 suggested
    Hi redgreenblue . I have been quite successful using the RC switch library: https://github.com/sui77/rc-switch/wiki https://github.com/sui77/rc-switch/wiki I've used an Arduino and a 433Mhz receiver, with…
  • neilk
    neilk over 9 years ago in reply to redgreenblue +1 suggested
    This is the approach I used: https://github.com/sui77/rc-switch/wiki/HowTo_Receive to decode the signals from my remote: I then used this sketch to transmit a code to my device: /* Send the code sequence…
  • neilk
    0 neilk over 9 years ago in reply to redgreenblue
    At least you know that your 433Mhz receivers work with Arduino and the rc-switch library image
    According to the rc-switch examples, if the receive demo sketch doesn't recognise the protocol it is receiving, then it should tell you.
    Are you sure that these Flash trigger units are 433Mhz? Some remote controllers work at  315Mhz or 330Mhz.
    What are the 4 switches supposed to do? Have you tried all combinations of the switches?
    Neil
  • neilk
    0 neilk over 9 years ago in reply to ajens23
    Hi ajens23 Hope you get to grips with it!
    Any problems, open a new thread & we'll try and help.
    All the best
    Neil
  • redgreenblue
    0 redgreenblue over 9 years ago in reply to neilk
    here I open another discution
    https://www.element14.com/community/message/209223/l/can-a-rf-signal-be-replicate-from-an-audio-capture#209223
  • neilk
    Hi redgreenblue I've just treated myself to a picoscope USB oscilloscope, which has allowed me to get closer to the 433MHz transmission protocols.
    Here is a capture of a 24bit transmission from one of my remote controls:
    If we assume that the narrow positive going pulses are "markers", the wide positive going pulses are "1"s and the wide low spaces are "0"s, then we can count 24 bits in the pattern.
    Reading from left to right, beginning with a marker, we can interpret the pattern as follows:  010001010000000100010101, which matches the output from the Arduino sketch ReceiveDemo_Advanced, from the RCSwitch library, shown below:
    If you have access to some kind of storage/USB scope, maybe you can do the same?
    Neil
  • redgreenblue
    I purchased a RTL-SDR USB dongle that work with SDR sofware. I expected to do exactly what you show up here.
    But I have not been able to make it work this way...all I get is signal that look like 'wave' form in which I cannot see the low and high of the signal.
    Your PicoScope seem to be exactly what I need!
    I've found numerous products when google ''picoscope'' but simply to get things faster,
    Can you give me more informations on which PicoScope I might need ?
    I'm new user to any kind of USB dongle that record, translate or interpret signals.
    So any advices from you Neil would be deeply appreciated!!
    Are you an hobby or professionnal electronics engineer ?
  • neilk
    Your RTL-SDR device clearly has the potential to be used in a variety of extremely sophisticated ways, most of which appear to be way above my pay-grade!! i followed through on some of the links and they look very complicated.
    The picoscope is a USB version of the good old electronics workhorse, the storage oscilloscope. I have the 2204A, which is the cheapest model available.
    In order to achieve the capture shown in my previous post, all I did was connect a probe from the picoscope to the 433Mhz receiver output (ie the one connected to pin 2 of the Arduino), set the picoscope trigger to auto and then hold down the remote button, adjusting the horizontal timebase until I could see 2 or three groups of pulses in the display. As you can probably see, the timebase setting is 10mS/div. This gives a good starting point.
    I then set the trigger to single and pressed the remote button again. This gave me a one-shot capture of the receiver output, which captured 1 complete data block and 2 partial data blocks. I could then focus on the complete data block and expand it for detailed examination. You may have to do this several times to get a good display and maybe readjust the timebase
    As to interpreting the data block, obviously, knowing what result I wanted to achieve (from the Arduino sketch) made things easier. I'm also lucky in that the protocols being used in the remotes I am working with are quite straightforward and supported by the RC-switch library.
    I am a retired software engineer, but I started my professional career in medical electronics, moving to software via digital electronics.
    Best wishes
    Neil
  • redgreenblue
    Great informations!  There some details you point out that I wasn't aware of, so thanks I might be able to decode the signals after all. I'm happy to know after all this is possible!
    I hope now I can get a 2204A used very cheap cuz I got to be honnest...  250$ for decoding signal for once or twice is expensive process.
    Not that 250$ is lot of money, simply becuz the picoscope will be sitting there gathering dust after I have found the signal.
    Any chances someone could 'rent' me a Picoscope !
    image  (Kidding)
    I'm glad this turn out to be working toward a near solution.
