Arduino Forum What kind of sensor can I use to determine approximate distance of small animal?
  • Replies 19 replies
  • Answers 9 answers
  • Subscribers 420 subscribers
  • Views 2111 views
nosrol
nosrol over 9 years ago
I am using an Arduino Uno and it will be in an inside environment. I want to determine if the arduino is getting closer or farther from a pet. I have been playing around with the idea of either a Microwave Doppler Radar, however, that is more for movement than distance. IR sensors won't detect through walls, plus the pets are black and absorb much of the radiaiton. Ultrasonic is out of the question as it disturbs the pets. Any other ideas or maybe something I am overlooking?
    DAB over 9 years ago +2 suggested
    Use the Grid Eye sensor. It can detect small IR signatures up to about 5 meters. DAB
  • COMPACT
    COMPACT over 9 years ago in reply to nosrol +2 suggested
    Use more cameras - on each side of the wall. Use RF to communicate to the cameras.
  • djfraz
    djfraz over 9 years ago +2 suggested
    Have you considered an iBeacon. Most mobile apps can give you a distance measurement once calibrated. It can be done using an intel edison, i think it can be done on the esp32 module as well
    0 DAB over 9 years ago
  • nosrol
    0 nosrol over 9 years ago in reply to DAB
    Would that be able to detect IR through walls as well?
  • koudelad
    0 koudelad over 9 years ago in reply to nosrol
    No, it can't detect objects behind a wall. However, you can use the module in every room / behind every wall to cover the whole area.
    How about using something more powerful like Raspberry Pi + a camera module and do an optical detection?
  • nosrol
    0 nosrol over 9 years ago in reply to koudelad
    Well I'm trying to keep this as low cost as possible but I believe I would still run into the same issue of line of sight no?
  • koudelad
    Well, yes, all optical methods have problems with detection of anything behind a material blocking light.
    It depends on what exactly you need to know about the position / distance and what are the specifics of your area. Anyway, not everything can be resolved with just one sensor.
  • COMPACT
    0 COMPACT over 9 years ago
    A stick. image
  • COMPACT
    0 COMPACT over 9 years ago in reply to COMPACT
    Just use a camera or an array of cameras (visual or thermal). The further away the animal the smaller it will appear ratiometrically.
  • nosrol
    0 nosrol over 9 years ago in reply to COMPACT
    That would not work as it wouldn't be able to detect them through walls. Got anything else?
  • nosrol
    Yes I understand that, that is why I was thinking of a simple RF system. The TX on the pet would transmit pulse and the arduino would then determine if it is getting closer or farther depending on the time between pulses. Do you think that is feasible?
    Depending upon the wall material, you might be able to use a capacitive sensor.
