Arduino Forum AWM 92100V AIRFLOW SENSOR INTERFACE WITH ARDUINO BOARD
  • Replies 7 replies
  • Subscribers 415 subscribers
  • Views 1599 views
rgp033
rgp033 over 9 years ago
Please any one help to interface  AWM92100VAWM92100V SENSOR WITH ARDUINO BOARD OR MICROCONTROLLER PLEASE HELP ME
  • jc2048
    jc2048 over 9 years ago in reply to rgp033 +1 verified
    The datasheet gives you wiring diagrams for the bridge and a circuit for driving the heater. You'll need to add a circuit that can generate an accurate supply (they suggest 10V held within 10mV). Then…
  • jc2048
    jc2048 over 9 years ago in reply to rgp033 +1 suggested
    Sorry, I don't have a circuit diagram. You could try contacting Honeywell and ask if they have a reference design. Alternatively, you could develop a circuit for yourself - the elements of what is required…
  • jc2048
    0 jc2048 over 9 years ago
    This one has I2C and would be much easier for you to interface to an Arduino
    http://uk.farnell.com/honeywell/hafblf0200c2ax5/sensor-zephyr-200cm-min-5v-long/dp/1894996
  • rgp033
    0 rgp033 over 9 years ago in reply to jc2048
    But sir i allredy but it so i want to interface AWM92100v with microcontroller so please give me guidence about that
  • jc2048
    0 jc2048 over 9 years ago in reply to rgp033
    Then you'll need to add a differential amplifier to amplify the output and offset it to run into the Arduino's A/D. You'll need a reference for the Arduino's A/D - maybe you could derive that from the accurate 10V supply which will incorporate a reference.
    Linearisation of the output you could do in software.
    Hope that helps.
    Personally, for a one-off, I'd either use one of the amplified modules or, even easier, the digital I2C one.
  • rgp033
    Can you send me the circuit duagram
  • rgp033
    Can you send me circuit diagram to interface AWM92100V sensor with arduino board
  • rgp033
    Please send me circuit diagram to interface AWM92100V sensor with arduino board
  • jc2048
    Alternatively, you could develop a circuit for yourself - the elements of what is required are quite straightforward and you can find plenty of material on the websites of the major manufacturers of op-amps (application notes, etc). Try Analog Devices and Texas Instruments to start with.
