Arduino Forum Getting started with arduino: what to buy
  • Replies 14 replies
  • Answers 6 answers
  • Subscribers 416 subscribers
  • Views 4669 views
98karlh
98karlh over 9 years ago
Hello e14
Environmental engineer from denmark checking in.
I am building a project in which I plan to use an arduino to measure and log/record sensor data.
This sensor data includes: temperature, pH, conductivity, gas/liquid flow, and light intensity (x2 sensors), all measured in an aquatic environment.
Initially I will set up and test each sensor individually, then later set up a full set of sensors, and finally I require up to 6 sets of the above mentioned sensors.
I have tinkered with professional lab equipment, but starting up for myself, my budget is a far cry from what is required.
so the tasks at hand are:
1: aquire the nessecery parts
2: get familiar with building and programming arduino
3: set up data logging
4: test each sensor
5: set up a full set of sensors
6: set up multiple paralel sets of sensors using preferably 1 arduino(?), otherwise multiple.
I would love your thoughts on step 1: aquiring the nessecery parts.
(max budget ca. 200$, preferably around 100 if possible)
-Purchase an all-around starter kit for arduino to first learn the basics, and then the additional parts needed in order to reach my end-goals?
-Genuine arduino vs. 'clones' ?
also ideas, questions and inputs are absolutely welcome!
With kind regards
-Karl
    shabaz over 9 years ago +4 suggested
    Hi Karl, You might also want to examine (to rule in or rule out) the Raspberry Pi, because if you wish to perform logging, then there are more options with it (micro SD card with file system, USB storage…
  • ntewinkel
    ntewinkel over 9 years ago in reply to shabaz +3 suggested
    > Arduino could be cheaper perhaps It is, especially if you start out with an inexpensive clone. However, after the FTDI incident, some clones now use a different USB-to-Serial chip which requires special…
  • beacon_dave
    beacon_dave over 9 years ago +2 suggested
    Perhaps take a look at these resources: Jeremy Blum Arduino Tutorials (here on Element 14) There is also a published book which covers similar ground. http://www.exploringarduino.com/ (Tutorial 11 covers…
  • 98karlh
    0 98karlh over 9 years ago in reply to beacon_dave
    Good call =)
    I have found a local shop selling uno R3 starter kits, and I am seriously considdering getting one from there, as I am hard pressed to wait much longer to get started image
    however, If it turns out I require a board with a a hiigher quality ADC, this is definately an option
    Thank you image
  • 98karlh
    0 98karlh over 9 years ago in reply to ntewinkel
    I agree completely, I will get an arduino uno kit, and do the tutorials in the manual, get a feel of it. and if needed later, 11$ is not too much that I can always grap a few with build in wifi, and apply what I have learned =)
    Thank you for your input, much appreciated =)
  • 98karlh
    0 98karlh over 9 years ago in reply to 14rhb
    I checked out the review, and it helped convince me that I want to start with a uno r3 starter kit. I will also order the required sd card expansion card, etc. and whn I am done with the tutorials (and others) I will proceed with my project.
    It seems like I will love working with this stuff, so why rush it, the manual looks lovely, I think I will enjoy it =)
    Thank you very much for your input!
  • beacon_dave
    0 beacon_dave over 9 years ago in reply to 98karlh
    If you start with Arduino and you want to go a step further then you can look at moving to AVR (the platform which powers the likes of the Arduino UNO).
    Dev boards are quite low cost and they are Arduino shield compatible e.g. I use one of these:
    328P Xplained Mini328P Xplained Mini boards.
    They can be made to work with Arduino IDE if you want to, but there is the Atmel Studio IDE if you don't.
    Ultimately, to reduce costs further you can then go down to the bare ATmega 328P chip (or similar AVR devices) for you projects.
