Arduino Forum Please I need help Writing code
  • Replies 51 replies
  • Answers 9 answers
  • Subscribers 420 subscribers
  • Views 6305 views
  • need help coding
  • need code written
theshay
theshay over 8 years ago
I am trying to write code for an automatic railroad crossing gates for my grandsons train table i built. I have no clue what i am doing. What i can say is im using 2 servos with external power 4 red leds that need to flash and a speaker for bell ding which i was hoping to use a sound file to play back my wire config is 2,3 for leds  2 servos 5,6 I also have a 10 second record-able device for train horn which uses push button for playback. i wanted to cut off the push button and use the arduino r3 to act as the push button pin 8. Also i will have 2 reed switches one to activate gates and lights and one to deactivate pins 4,7 this is what i have so far I get the lights to flash but im lost from there can some one help me write this code?
int rd1LEDPin=2; //Declares rd1LED as int and set to 2
int rd2LEDPin=3; //declairs rd2LED as int and set to 3
int rd1onTime=250; //light 1 on time
int rd1offTime=250;  // light 1 off time
int rd2onTime=250; //light 2 on time
int rd2offTime=250;  // light 2 off time
const int REED_PIN = 4; // Pin connected to reed switch
const int REED_PIN = 7; // Pin connected to reed switch
const int LED_PIN = 13; // LED pin - active-high
void setup() {
  pinMode(rd1LEDPin, OUTPUT);// sets the second pin for output
   pinMode(rd2LEDPin, OUTPUT);// sets the third pin for output
  Serial.begin(9600);
  // Since the other end of the reed switch is connected to ground, we need
  // to pull-up the reed switch pin internally.
  pinMode(REED_PIN, INPUT_PULLUP);
  pinMode(LED_PIN, OUTPUT);
void loop() {
  digitalWrite(rd1LEDPin,HIGH); //turns led 1 on
  digitalWrite(rd2LEDPin,LOW); // turns led 2 off
  delay (rd1onTime); //wait
  delay(rd2offTime); //wait
  digitalWrite(rd1LEDPin,LOW); //turns led 1 off
  digitalWrite(rd2LEDPin,HIGH);//turns led 2 on
  delay (rd1offTime);//  wait
  delay(rd2onTime);  //wait
  int proximity = digitalRead(REED_PIN); // Read the state of the switch
  if (proximity == LOW) // If the pin reads low, the switch is closed.
    Serial.println("Switch closed");
    digitalWrite(LED_PIN, HIGH); // Turn the LED on
  else
    digitalWrite(LED_PIN, LOW); // Turn the LED off
  • theshay
    theshay over 8 years ago in reply to andywest +4 suggested
    ok i changed it. please for give me im an old man trying to do something for my autistic grandson he loves trains. so i build him a table for his birthday. only thing left to do is make the crossing gates…
  • jomoenginer
    jomoenginer over 8 years ago in reply to theshay +3 suggested
    Considering your lack of code development background, gabbing code examples might be causing more of an issue for you than it may solve. My suggestion for you is to write out what you want the code to…
  • theshay
    theshay over 8 years ago in reply to balearicdynamics +3
    Thank you so very much Enrico You are truly an honor and a scholar. May the guiding light be with you! I cant thank you enough for helping me. you really got me out of a jam. :-))) Not sure if you travel…
  • theshay
    0 theshay over 8 years ago in reply to mcb1
    thank you for your help:-))
  • theshay
    0 theshay over 8 years ago in reply to balearicdynamics
    I appreciate you taking the time to help me with this your awesome!!
  • theshay
    Enrico,
         Not sure if you had a chance to look at the new code and schematic I posted. I think it would be easier to modify because it is closest to what i am looking for. it only needs the switches added. Unfortunately Ive been trying to figure it out myself but just not getting it. Everyone has advice but I don't think they understand I know nothing about writing code. I wish i had more time to learn, going forward I will be doing more tutorials Because I really like the possibilities of the Arduino system and am interested in learning but for now im in a jam. I appreciate any and all help you can give me. Again I would like to thank you for your time, as I'm sure you have better things to do.
    0 balearicdynamics over 8 years ago in reply to theshay
    Hello Edward,
    here it is midnight. I should solve a problem of mine then I will check your source to my Arduino. I think I can do it tomorrow morning...
  • theshay
    Enrico,
         Ok I really appreciate you helping me. I wasn't for sure if you had seen the new stuff i posted. it is 6:30pm here im usually up all nite as I am retired. I will post some pics of the table and a video once I get it operating correctly. I am currently running all my wire for lights ect.. servos and crossing lights are already ran just need to hook to Arduino.Again I thank you very much and look forward to hearing from you.
    0 mcb1 over 8 years ago
    theshay
    Did you try the code change I gave you?
    here https://www.element14.com/community/message/238294/l/re-please-i-need-help-writing-code#238294
    I suggested replacing the line
    int sensorValue = analogRead(PIN_SENSOR);
    with
    by adding this in the top section
    const int trainDetector = 8;  // reed switch to detect train is present
    and this
    if (digitalRead (trainDetector) == LOW)
  • theshay
    Great! Really, a nice scenario image I finally I am closing my stuff tonight and thanks God tomorrow morning I can put your code on an Arduino, then test what's happens. I hope I have not delayed too much and this can be helpful to you.
    Enrico
  • 14rhb
    0 14rhb over 8 years ago in reply to theshay
    Edward,
    That is a great setup you have there.
    Rod
  • theshay
    Enrico,
         No problem brother I appreciate your help. still plenty of time i have almost two weeks to finish up. I ordered a few more things off line to add they should be here by the weekend. I am adding camping tents and campers around the two fire pits, one is on the mountain looks like a black circle, it is actually lighted just not wired yet. to wire everything will only take me 1 day, I also ordered more street lights to put around the track those are all working lights too just like the ones in the beach parking lot. the empty corner to the lower right is where the petrol station is going. I am building that with foam core board and printed designs. All of the grass is stained saw dust instead of spending 30 bucks or more just for fake grass. trees are branches cut from a bush and glued deer moss and painted. The reeds along the lake side are chip brushes taken apart then glued the bristles into clusters.  All of the miniature people I ordered off wish.com for 2 bucks free shipping. Arduino card from wish for 5 bucks and a clear case for Arduino 2 bucks on wish. The street lamps I got 20 for 10 bucks on wish.comThe parking-lot and roads are printed then glued on foam core. The power to run everything with plenty of add on room is a 200watt computer supply converted into 3v, 5, 12v outputs all packed neatly into a service box used to be old fuse box for my garage. the train, not all shown I have had since the mid 80's. The slot car track I bought 2 years ago for my grandson to play with when he visits. He keeps asking me where it is and can he play with it. I,m so excited I can't wait to see the look on his face when he sees what grandpa has made for him. :-))
