Arduino Forum water flow sensor
  • Replies 11 replies
  • Answers 6 answers
  • Subscribers 417 subscribers
  • Views 2044 views
water flow sensor
ahmedhodhod
ahmedhodhod over 8 years ago
Can anyone please help me i can not save value of total liters in eeprom,the main problem it read and writing while arduino mega working but if power of the value saved in eeprom go back to 0 because the counter  starting from 0
    mcb1 over 8 years ago in reply to ahmedhodhod +5 suggested
    ahmedhodhod Are you sure this is the code you've loaded into your Arduino.? I found numerous parts that needed to be commented out just to compile it, but I was using an UNO. There is a an incorrectly…
    jw0752 over 8 years ago +3 suggested
    Hi Ahmed, You will probably have to provide a little more information and your code for someone to be able to figure out how to help. John
    mcb1 over 8 years ago +2 suggested
    If you include the code you have, we can offer some ideas. Mark
  • ahmedhodhod
    0 ahmedhodhod over 8 years ago in reply to mcb1
    thanks for your reply , the sketch maybe not compile with you because only compile with arduino mega
    i think the value that stored in eeprom in address 1 reset to 0 due to totalMilliLitres value reset to 0 . check the line number 88 pulse count = 0 and void water_daily() declared in void loop  .
    So what happens here I think is Every time the counter increases, the last value is stored, and when you return to zero, the value is stored zero because the counter returns the value zero again and so on. you can say as rolling odometer
    and for divide   eeprom_daily = totalMilliLitres /1000 return 1 not less than this value
