Arduino Forum water flow sensor
  • Replies 11 replies
  • Answers 6 answers
  • Subscribers 417 subscribers
  • Views 2032 views
water flow sensor
ahmedhodhod
ahmedhodhod over 8 years ago
Can anyone please help me i can not save value of total liters in eeprom,the main problem it read and writing while arduino mega working but if power of the value saved in eeprom go back to 0 because the counter  starting from 0
    mcb1 over 8 years ago in reply to ahmedhodhod +5 suggested
    ahmedhodhod Are you sure this is the code you've loaded into your Arduino.? I found numerous parts that needed to be commented out just to compile it, but I was using an UNO. There is a an incorrectly…
    jw0752 over 8 years ago +3 suggested
    Hi Ahmed, You will probably have to provide a little more information and your code for someone to be able to figure out how to help. John
    mcb1 over 8 years ago +2 suggested
    If you include the code you have, we can offer some ideas. Mark
    0 jw0752 over 8 years ago
    Hi Ahmed,
    0 mcb1 over 8 years ago
  • beacon_dave
    0 beacon_dave over 8 years ago
    Sounds like you are storing the values in RAM and not in EEPROM memory.
    There are examples of using the EEPROM memory available here:
    https://www.arduino.cc/en/Reference/EEPROM
  • ahmedhodhod
    0 ahmedhodhod over 8 years ago
    #include <EEPROM.h>
    #include <Wire.h>
    #include "RTCLib.h"
    #include "Arduino.h"
    byte sensorInterrupt = 0;
    byte sensorPin       = 2;
    float calibrationFactor = 4.5;
    volatile byte pulseCount;
    float flowRate;
    unsigned int flowMilliLitres;
    unsigned long totalMilliLitres;
    unsigned long oldTime;
    int eeprom_daily,eeprom_weekly,eeprom_monthly;
    char buffer[10] = {0};
    char buffer_str[10];
    NexButton exit15 = NexButton(15, 4,"exit15");
    NexButton setting15 = NexButton(15, 5,"setting15");
    NexButton del = NexButton(15, 6,"del");
    NexText daily = NexText(15, 7, "daily");
    NexText ML = NexText(15, 1, "ml");
    NexText weekly = NexText(15, 2, "weekly");
    NexText monthly = NexText(15, 3, "monthly");
    void waterPopCallback(void *ptr)
      page15.show();
      char buffer_water[10];
      itoa(eeprom_daily,buffer_water,10);
      daily.setText(buffer_water);
      water_read ();
    void water_setup ()
      pinMode(sensorPin, INPUT);
      digitalWrite(sensorPin, HIGH);
      pulseCount        = 0;
      flowRate          = 0.0;
      flowMilliLitres   = 0;
      totalMilliLitres  = 0;
      oldTime           = 0;
      attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
    void water_read ()
      if((millis() - oldTime) > 1000)
      detachInterrupt(sensorInterrupt);
      flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
      oldTime = millis();
      flowMilliLitres = (flowRate / 60) * 1000;
      totalMilliLitres += flowMilliLitres;
      unsigned int frac;
      memset(buffer, 0, sizeof(buffer)); // clear buffer
      itoa(totalMilliLitres, buffer, 10);
      ML.setText(buffer);
      event = true;
      pulseCount = 0;
    void pulseCounter()
      // Increment the pulse counter
      pulseCount++;
    void setup(void)
        Serial.begin(9600);
      if (EEPROM.read(0) != 0xFF)//init eeprom
      init_eeprom();
      read_init_eeprom();
    water_setup ();
    void loop(void)
      nexLoop(nex_listen_list);
      water_daily();
     water_read ();
    void init_eeprom()
      Serial.print("Reset Setting ...");
      EEPROM.write(0,0xFF); //check
      EEPROM.put(1,0);
      Serial.println(" Done");
    void read_init_eeprom()
      Serial.print("Read Setting ...");
     //eeprom_daily =(int) EEPROM.get(13);
     EEPROM.get(1, eeprom_daily);
    void water_daily(){
     if (totalMilliLitres > 0)
      eeprom_daily = totalMilliLitres /1000;
     Serial.println ("water_daily");
     EEPROM.put(1,eeprom_daily);
  • ahmedhodhod
    0 ahmedhodhod over 8 years ago in reply to jw0752
    kindly check my code
  • ahmedhodhod
    0 ahmedhodhod over 8 years ago in reply to mcb1
    i have posted my code kindly check
  • ahmedhodhod
    0 ahmedhodhod over 8 years ago in reply to beacon_dave
    i write the values to eeprom check my code
    0 mcb1 over 8 years ago in reply to ahmedhodhod
    Yes we can see ... it appears in our inbox. (and all the other people)
    Eventually when I put aside my work, I'll have a look.
    However it might be another day before I can, so please bear with us as we're not paid support staff, we simply other members of this community.
  • ahmedhodhod
    thanks for your time
    ahmedhodhod
    There is a an incorrectly placed } at line 111 and the sketch is missing one at the end.
    Eeprom is a byte value only ... that is it must be a number between 0 and 255.
    So each location address has a byte.
    I'm not sure what value the totalMilliLitres is, but you are dividing it by 1000 which makes it Litres.
    I've never used put and get, but it appears that this will place the value over an address, ie not a single address (1 in your case)
    You can see this here https://www.arduino.cc/en/Tutorial/EEPROMPut
    In your sketch you are simply writing it to address 1 which may not be enough given that the totalMilliLitres has been declared as a 'long'.
    You should be able to determine if the issue is related to the Intialisation routine as it prints "Reset Setting .... "
    You haven't shown us the serial print so we left guessing as to what it is doing.
    A copy of the actual Serial messages would be useful to see if it is actually working as it should be.
    I suspect your problem is related to the sketch process, rather than how you are writing it.
    You're reading the value stored in the eeprom as eeprom_daily, but you rewrite this each time the totalMilliLitres is greater than 0.
    The value you putting into address 1 is the totalMilliLitres/1000 which is likely to be less than 1.
    So whenever you get 100ml of water used, you call void water_daily() and then divide 100 by 1000 (which returns 0.1)
    The totalMilliLitres is decalred as an unsigned long (see here https://www.arduino.cc/reference/en/language/variables/data-types/unsignedlong/  )
    Unsigned long variables are extended size variables for number storage, and store 32 bits (4 bytes). Unlike standard longs unsigned longs won’t store negative numbers, making their range from 0 to 4,294,967,295 (2^32 - 1).
    So I suspect you are always storing a zero, and hence your sketch is working as it should, but not the way you expect it.
    • Vote Up +5 Vote Down
