Arduino Forum Controlling arduino with Python (Syntax in code help please :'( )
  • Subscribers 414 subscribers
  • Views 669 views
the_future
the_future over 8 years ago
My Code:
import serial                                 # add Serial library for Serial communication
Arduino_Serial = serial.Serial('com4',9600)  #Create Serial port object called arduinoSerialData
print Arduino_Serial.readline()               #read the serial data and print it as line
print ("Enter 1 to ON LED and 0 to OFF LED")
while 1:                                      #infinite loop
    input_data = raw_input()                  #waits until user enters data
    print "you entered", input_data           #prints the data for confirmation
    if (input_data == '1'):                   #if the entered data is 1
        Arduino_Serial.write('1')             #send 1 to arduino
        print ("LED ON")
    if (input_data == '0'):                   #if the entered data is 0
        Arduino_Serial.write('0')             #send 0 to arduino
        print ("LED OFF")
have no idea why
  • jj57
    0 jj57 over 8 years ago
    The example you are using is coded using Python 2.x, but you are using Python 3.x.
    One of the main differences between 2.x and 3.x is that print requires parentheses in 3.x.
    The key differences between Python 2.7.x and Python 3.x with examples
