Arduino Forum compare two ac singal within a 5v rail PCB
  • Subscribers 415 subscribers
  • Views 587 views
anishkgt
anishkgt over 8 years ago
hi All,
I am trying to design a comparator where the max voltage on the PCB is limited to 5v.
I am trying to compare an ac voltage when it drops below 32v but not sure how to set the reference voltage. here is a schematic i had come with but not sure how to move forward with a reference voltage. I had designed it after several iterations where the ac voltage was way below 2vac. Now managed to bring the voltage up 30vac. This a a followup from my previous post
  • anishkgt
    0 anishkgt over 8 years ago
    aiming to have the comparator to go HIGH when the voltage drops below 33 and LOW when above it.
  • anishkgt
    0 anishkgt over 8 years ago in reply to anishkgt
    the comparator should work like this,
    Below 33 - HIGH
    Above - LOW
    got this when voltage at the primary of the MOT (load) and 26vac when the secondary are shorted.
    so 26vac is 16.5vdc and divide it by 5 gives a 3.3v which i guess should be the reference voltage ? and 33vac is 20.9vdc and divide it by 5 is about 4.1v
  • anishkgt
    Seem to have partially got it, at 26vac vout should read HIGH but its low and at reads LOW above 30, which it does.
