Arduino Forum Please help me to debug this programme
  • Answers 4 answers
  • Subscribers 417 subscribers
  • Views 958 views
richipearl
richipearl over 8 years ago
I wrote the following code to make a seven digit segment display number from 1 to 9 continuously but while compiling the arduino ide write error, too many argument  to function turnOn
byte ledPin[7]={2,3,4,5,6,8,9};
#define buttonPin 11
int no = 0;
int pushButton = 0;
void setup() {
  for(int a = 0;a < 7;a++){
  pinMode(ledPin[a],OUTPUT);
  pinMode(buttonPin,INPUT_PULLUP);
  turnOn();
  // put your setup code here, to run once:
void turnOn()
  pushButton = digitalRead(buttonPin);
    if (pushButton == LOW)
    no++;
    delay(200);
switch(no)
    case 1:
      digitalWrite(ledPin[0],LOW);
      digitalWrite(ledPin[1],HIGH);
      digitalWrite(ledPin[2],HIGH);
      digitalWrite(ledPin[3],LOW);
      digitalWrite(ledPin[4],LOW);
      digitalWrite(ledPin[5],LOW);
      digitalWrite(ledPin[6],LOW);
      break;
    case 2:
     digitalWrite(ledPin[0],HIGH);
     digitalWrite(ledPin[1],LOW);
     digitalWrite(ledPin[3],HIGH);
     digitalWrite(ledPin[4],HIGH);
     digitalWrite(ledPin[5],HIGH);
     break;
    case 3:
      break;
    case 4:
    digitalWrite(ledPin[6],HIGH);
    break;
   case 5:
   digitalWrite(ledPin[2],LOW);
   break;
  case 6:
    break;
  case 7:
    break;
  case 8:
      break;
  case 9:
    break;
void loop()
  for (int b = 0;b < 10;b++)
    turnOn(b);
    delay(500);
// put your main code here, to run repeated
  • Fred27
    Fred27 over 8 years ago in reply to richipearl +5 suggested
    There's not a huge amount the explain. Only one line needs to change. turnOn(b); need to become turnOn(); void loop() { for (int b = 0;b < 10;b++) { turnOn(); delay(500); } } Of course, once it compiles…
    Jan Cumps over 8 years ago +4 suggested
    your turnOn() function expects 0 parameters, but you pass it 1 parameter: turnOn(b)
  • afmishaq
    afmishaq over 8 years ago in reply to richipearl +2 suggested
    Rachel, You have defined your function as: void turnOn() The initial void says that it will not return anything which is fine because your function will just turn on some LED segments and does not need…
    0 Jan Cumps over 8 years ago
  • richipearl
    0 richipearl over 8 years ago in reply to Jan Cumps
    Thanks for your contribution but can you please explain more
  • Fred27
    0 Fred27 over 8 years ago in reply to richipearl
    void loop()
        turnOn();
        delay(500);
    Of course, once it compiles then it may not do exactly what you were expecting. It's best to tackle this one step at a time and work through the bugs. That's the only way you'll get an understanding of what you're trying to do.
    • Vote Up +5 Vote Down
  • afmishaq
    0 afmishaq over 8 years ago in reply to richipearl
    Rachel,
    The initial void says that it will not return anything which is fine because your function will just turn on  some LED segments and does not need to return any value.
    However, the empty brackets say that it does not any arguments. This is not correct because you need to pass a number to turn on the desired segments. So, you have to put something in the brackets to indicate tthat you will be passing an argument. In your case, you are passing an integer value, so you may write 'int b' there.
    Hope this helps,
    Faiz
  • beacon_dave
    0 beacon_dave over 8 years ago
    Looks like you have an opening brace in the wrong place as well:
    void turnOn()
        no++;
        delay(200);
    perhaps should be:
    void turnOn()
        no++;
        delay(200);
  • richipearl
    Thanks so much to everyone's contribution
    byte ledPin[7]={2,3,4,5,6,8,9};// declare pins to led
    #define buttonPin 11 // set buttonpin
    int no = 0;
    int pushButton = 0;
    void setup() {
      }               // set ledPin as output
      pinMode(buttonPin,INPUT);  // set buttonPin to input
      void loop()
        turnOn();   // declare turnOn as function
        if(no > 9)
          no = 0;
      void turnOn()
      pushButton = digitalRead(buttonPin);// set the pushbutton to read into from the button
      delay(500);
        if (pushButton == LOW) // when buttonPress is detected display number
        no++;
    switch(no)
        case 1:
          break;
        case 2:
         break;
        case 3:
          break;
        case 4:
        break;
       case 5:
       break;
      case 6:
        break;
      case 7:
        break;
      case 8:
          break;
      case 9:
        break;
    my code is now working
