Arduino Forum Location Tracking
  • Replies 17 replies
  • Answers 9 answers
  • Subscribers 418 subscribers
  • Views 3659 views
Location Tracking
rgiguere
rgiguere over 8 years ago
Ok so we have all seen autonomous lawnmowers. I am currently building my own which is relatively easy to do the problem is location tracking.  I do not want to use a bunch of burried wire to create a path for it to follow and just setting up a perimeter makes it wander around aimlessly. GPS is not accurate enough to get propper location RF signals seem to be extremely complicated and relatively expensive so my question is is there any other way to track the location of a rover acuratley enough to be within 1 foot or less?
    shabaz over 8 years ago +4 suggested
    Hi Robert, Without local things to sense (like buried wires etc) I think it's not easy to do it repeatably with reliability, and that's of prime importance for your use-case I guess. If you have the ability…
  • Gough Lui
    Gough Lui over 8 years ago in reply to shabaz +3 suggested
    If not via a visual system, radio is a bit tricky to localise, but light generally is not. I wonder whether you could rig up some criss-crossed high-power infrared beams or something like that. Detect…
    jw0752 over 8 years ago +3 suggested
    I have a robot vacuum cleaner that does a great job of mapping a room. It has several forms of obstacle detection but seems to have a way of counting its steps (wheel revs) and keeping track of its direction…
    0 mcb1 over 8 years ago in reply to rgiguere
    Trimble used to do this and it was used by Local authorities.
    This was back in the day when there was a deliberate 'wobble' on GPS signals for 'domestic' use, but as I understand they came to an agreement and it was removed.
    Aviation DME's use the time of signal to determine distance but the type of accuracy you're looking for is too small.
    Ultrasonic time of flight might work, but you're also going to encounter wind changing it.
    The newer 'no moving parts' Anenometers are based on this principle with three heads at a known distance to give wind speed and direction.
    You could certainly determine angle easily, it just the distance bit.
  • Gough Lui
    0 Gough Lui over 8 years ago in reply to mcb1
    Glad Bill Clinton ordered the turning off of Selective Availability. If we had access to the military receivers, they're about 10x as accurate due to the higher chipping frequency. Carrier phase tracking GPS as used by surveyors are quite expensive - but there were some localized GPS-like units like Locata that could measure distances from a known sirvey point reference station. Still a highly expensive endeavour.
    If all one wants to do is mow tthe lawn, perhaps some beefy motors, rope and pulleys would do. Have the lawnmower like the head of a 2D plotter and pull it around with two ropes - X and Y. Unless the rope is cut, you know where it's at by measuring/encoding revolutions on the pulley.
    One thing we should be careful of is safety. We don't need motorized equipment going AWOL.
    - Gough
  • rgiguere
    0 rgiguere over 8 years ago in reply to mcb1
    I thpught of using ultra sonic sensors for the prototype  but i just cant seem to find any that will travel across a distance greater than a few inches,  great for avoidance but thats about it.  I am really intrigued by the gps method i just found a gps by navspark that has RTK built in for roughly 80 dollars and works with srduino and Raspberry pi i ordered one since the price was good so i guess we will see thanks for your input much appreciated
  • Gough Lui
    0 Gough Lui over 8 years ago in reply to rgiguere
    As far as I know, RTK still needs a reference base station to function and those are very expensive.
    - Gough
  • rgiguere
    0 rgiguere over 8 years ago in reply to Gough Lui
    Ok so I found an RTKLIB for raspberry pi im going to attempt a basestation around that and see what happens
    0 dougw over 8 years ago in reply to rgiguere
    Maxbotix makes lots of longer range ultrasonic sensors for example MB7363 is an outdoor sensor that reaches 10 meters.
  • abrain
    0 abrain over 8 years ago in reply to shabaz
    I’ve heard that the in store location tracking measures the signal strength to your smartphone WiFi transmitter in your pocket from a number of strategically located base stations... I’m not paranoid, I just don’t like the idea of other people tracking me around, so I’ll often be found in flight mode! 51148.contentimage_1.png
    A
