    • Avnet Boards Community
Arduino Forum Robot Following The Person
  • Replies 12 replies
  • Subscribers 393 subscribers
  • Views 949 views
I am working on a project, i.e following of a person by a robot.
I am not an expert although know enough to start with.
Please give me suggestions about the sensors so that i could use , which will help the robot to follow the person, also with suggestions please tell me a little how to use them.
NOTE: the robot should follow the specific person only if there are others.
PLEASE HELP!!
THANKs
  • Workshopshed
    Workshopshed over 10 years ago +4
  • fvan
    fvan over 10 years ago +2
    Have you seen this Ben Heck episode? Episode 38: See Ben Build an Autonomous Robot Luggage! He builds a suitcase that can follow him around, using ultrasonic sensors. Frederick
  • martinvalencia
    martinvalencia over 10 years ago +1
    You could use a webcam to recognize colors, such pre program the color polo that person use in this moment!
    Former Member over 10 years ago in reply to Former Member
    Brian, Its probably the best suggestion, so thanks for that.
    I had one problem, and that is ,that if you dont mind would you evaluate a little as i am not too much expert, or will you recommend some source?
    You're welcome Abid.
    Certainly I can give you some ideas, concepts, and sources for code examples.  Give me a day or two and I'll post links and info back here.  If you'd rather I send you info via email I can do that also.
    Brian
