Arduino Forum Creating DuPont equivalent crimp terminal
  • Replies 23 replies
  • Answers 12 answers
  • Subscribers 413 subscribers
  • Views 6656 views
Andrew J
Andrew J over 7 years ago
What’s the generic term for the single pin crimp terminal to stick on the end of a wire in order to push into an Arduino header socket?  I’m used to the term Dupont connector but this isn’t a search term recognised by Farnell or CPC and there seems to be a fair mix of crimp terminals that may or may not be correct.
    dougw over 7 years ago +8 suggested
    They are crimp sockets in rectangular housings but there are many terms used by different manufacturers and distributors. Consequently they are difficult to find, even though they are very common and almost…
  • fmilburn
    fmilburn over 7 years ago +8 suggested
    I have recently started crimping my own and have some Amphenol as well as inexpensive Chinese pins and sockets. I have the crimper that Shabaz linked above and like it. The Amphenol work well. The Chinese…
    shabaz over 7 years ago +7 suggested
    Hi Andrew, I think it's just called a crimp socket, or a 0.1" SIL socket crimp terminal. Anyway, a typical one is this crimp socket crimp socket , it fits the 0.1" SIL pin headers on the Arduino. There…
  • Soura_123
    0 Soura_123 over 3 years ago
    I guess crimping is rarely reqd in a single pin connector.It just fits in socket in Arduino board.I used to have a crimping tool that can be both used for Wire stripping & for crimping & splicing purposes.
  • BigG
    0 BigG over 3 years ago in reply to Soura_123
    Indeed so. In my case I need a wire length of about 750mm. Hence I went to search for these connectors. Something I seldom do.
    0 shabaz over 3 years ago
    This doesn't really address the question, but worth putting here since it is related to the mating end, i.e. crimp sockets...
    This sort of tool is great.. AMP 90202-2, which is really low-cost in used condition. Just saw this on ebay today for instance:
    I end up using it on almost every prototype, since I use pin headers (instead of sockets) on stripboards etc, so the tool is used for the sockets part code 2226TG which fits normal pin headers. The tool and that socket work great.. 100% success rate, and the tool allows for a selection of insulation thickness and stranded wire thickness, and it's easier to use that tool than the normal handheld ratchet tools.
    I don't use crimp pins much (that tool is definitely not suitable for them since it slightly bends the pins, although it is OK-ish at a pinch), but if I need a temporary connection to just a few signals, then I might pull out pins from a pin header, and half push them into the socket, to alter it from a socket into a pin.
