Arduino Forum Complete beginner requiring help with Bluefruit Feather programming
  • Replies 25 replies
  • Answers 18 answers
  • Subscribers 417 subscribers
  • Views 5078 views
marks+
marks+ over 7 years ago
Hello, I’m completely new to the Arduino family of PCBs & I have no experience of using them. So I have found myself in at the deep end without a clue!
We use Bluefruit Feather PCB nRF52832 for our products. The software we’re using is the official Arduino software.
It appears we can plug the boards into the PC via a standard USB lead and program them by opening a “sketch” and select “upload”.
The software compiles the sketches and then attempts to transfer them to the Feather. We then start getting messages saying there are errors or we need to update the bootloader or the boards are not in “DFU”mode.
We have tried updating and looked up and tried DFU mode but have had no joy.
I believe I may have discovered that our USB cable maybe of the wrong type, so I have another I'm going to be trying in the morning.
I have also downloaded the software on a different laptop to see if that makes a difference.
I have no doubt I am doing something incredibly simply wrong but would appreciate some advice on how to proceed.
TIA
  • fmilburn
    fmilburn over 7 years ago in reply to marks+ +5 suggested
    I have not used the Nrf Bluefruit feathers so can’t really comment on that. I have used a M0 and M4 express feather without a problem on Windows 10. They both came configured to use Circuit Python if I…
  • cstanton
    cstanton over 7 years ago in reply to marks+ +3 suggested
    marks+ , looks like you're getting two different error messages here. Your error message at https://www.element14.com/community/message/283091/l/re-complete-beginner-requiring-help-with-bluefruit-feather…
  • 14rhb
    14rhb over 7 years ago +2 suggested
    Hi marks+ Just to check, have you selected the correct board under the board manager tab? Looks like you need to set a few things up first as well: https://learn.adafruit.com/bluefruit-nrf52-feather-learning…
  • marks+
    0 marks+ over 7 years ago in reply to 14rhb
    Will do, just been trying to get rid of the space between my User Name, Mark D, which has proved problematic, so I'm trying to move the Arduino folders higher up the drive
  • marks+
    Here is the screenshot of the error message when I try to upload a sketch. Interestingly (or not) the root for the sketch remains the original one despite  me moving it.
  • 14rhb
    0 14rhb over 7 years ago in reply to marks+
    I was almost out of ideas, you know the USB cable is good as you programmed other boards and also seem to be selecting the correct board etc. So I used your screenshot and searched the internet and found this article: https://forums.adafruit.com/viewtopic.php?f=8&t=151796
    The errors are almost identical to your screenshot....which is promising, and the posts are from back in May 2019 (so not too old either).
    They discuss a "double reset" to force into dfu mode. The Original Poster expressed thanks that it worked so it might work for you also.
  • marks+
    Thanks again, I'll take a look.
    Before posting on this forum, a few days ago, I did try doing factory resets for the boards. This involved grounding the DFU pin and pressing reset button for 5 seconds....after no success I then posted on here.....
    I'll have a read and attempt what's in the link, cheers!!
  • 14rhb
    The third post on this thread https://forums.adafruit.com/viewtopic.php?t=87391  talks about pressing the reset quickly as you would a mouse button e.g. the "fast double reset"
    Hopefully that might work for you also.
  • marks+
    Sadly still cannot do either, upload the sketch or update the bootloader.
  • 14rhb
    I'm sorry I couldn't help you on this marks+ . Maybe with your screenshots posted someone will notice what the issue is or suggest what to try next.
    The only thing I can still see is the "tools/burn bootloader"....but that might end in bricking the device!
  • marks+
    No problem, thanks very much for your assistance. in a way I'm pleased it's not my noob status to arduino.
    Am I likely to have the same issue if I was to use an adafruit feather instead of a bluefruit feather?
  • fmilburn
    0 fmilburn over 7 years ago in reply to marks+
    I have not used the Nrf Bluefruit feathers so can’t really comment on that.  I have used a M0 and M4 express feather without a problem on Windows 10.  They both came configured to use Circuit Python if I remember correctly but you should not need to replace the bootloader.  There are directions on how to switch back and forth between Arduino and Circuit Python on the Adafruit site.  You might make a post on the Adafruit site with your problem.  The one experience I had there was a good one and they responded quickly.
    • Vote Up +5 Vote Down
  • 14rhb
    You are welcome. Without any research to back this statement up: IMO Adafruit have a much better user base and therefore issues will be resolved quickly, if they haven't already. Therefore if you can afford the cost of additonal boards, the Adafruit Feather does sound like a credible way to progress your work.
