Arduino Forum Turning on the LED after a while.
  • +1 person also asked this people also asked this
  • Replies 18 replies
  • Answers 8 answers
  • Subscribers 417 subscribers
  • Views 5715 views
  • led;
  • time
sonys
sonys over 6 years ago
Hello everyone.
The task:
Use the button to turn on and off the LED after a while.
For example, we pressed a button - the LED turned on and went out after 10 seconds. And so it should turn itself on every 5 minutes for 10 seconds. Then, press the button and the LED stops working and until the next button press, it does not work.
What features are better to use? Or who has a similar example?
    jw0752 over 6 years ago +4 suggested
    Hi Sofiia, If you do not need to use an arduino I believe a dedicated circuit using two 555 timers and a flip flop will be able to produce this effect. John
    shabaz over 6 years ago +3 suggested
    Hi Sofiia, To do this properly is quite an advanced thing. There's a capability inside the Arduino (it is slightly different depending on which Arduino you are using, but at a high level, the concept is…
  • ankur608
    ankur608 over 6 years ago +2 suggested
    For simplicity, you can replace your button with 'push on-off' or add an another 'tact switch' for the same. This will make your code routine much easier. Remember things that can't be reached with just…
  • beacon_dave
    0 beacon_dave over 6 years ago in reply to shabaz
    Another couple of potentially useful resources:
    Level Up Your Arduino Code: External Interrupts
    https://www.youtube.com/watch?v=J61_PKyWjxU
    Level Up Your Arduino Code: Timer Interrupts
    https://www.youtube.com/watch?v=2kr5A350H7E
    This one is not Arduino IDE but still a good introduction to the AVR peripherals such as GPIO and timer/counters:
    Getting Started With AVR
    https://www.youtube.com/playlist?list=PLtQdQmNK_0DRhBWYZ32BEILOykXLpJ8tP
    0 shabaz over 6 years ago in reply to sonys
    Hi Sofiia,
    There are two 'void loop', one needs removing.
    You can delete lines 41-46 (that part looks like a test program to blink an LED).
    Or you can write before line 41:
    #ifdef my_test
    and after line 46:
    #endif
    You can wrap any area of code you don't want to run like that.
    (or use // on each line).
    There's no guideline on where to write the values, it just needs to be done wherever you suspect (after running the code and seeing the result for example) there could be an error, or wherever you want to be sure the value is changing as expected.
    You can comment them out afterwards if you don't need them after debugging.
  • ankur608
    0 ankur608 over 6 years ago in reply to sonys
    Don't use void loop() func. twice as suggested by Shabaz, and the token error is usually due to wrong closure of {\}. Define the blink sequence under (regim==1) while maintaining the 'flag' logic. Hence, avoiding another loop function.
    While, you can possibly define another functional loop in your program. Last tip, (optionally) you can use millis() func. instead of delay() for speeding & defining processes on single-core Arduino.
  • sonys
    0 sonys over 6 years ago in reply to shabaz
    So my task was that when the button was pressed, the LED was turned on for 10 seconds, then turned off and after 5 minutes turned on again for 10 seconds. And so on until the button is pressed again. If I remove lines 41-46, as you advise, then my LED will not flash in the desired mode.
  • sonys
    0 sonys over 6 years ago in reply to ankur608
    I checked all the brackets. Everything should work, but the error is still the same. I didn’t work with the millis function, so it’s easier for me to convert via "delay"
  • ankur608
    Re-iterate the code 41-46(seq.) in buttonpressed state. Hope this helps.
  • ankur608
    Treat 'millis' as suggestion, you can use "delay".
