Arduino Forum Arduino Chipsets
  • Subscribers 414 subscribers
  • Views 1316 views
  • arduino nano sense
  • arduino chipset
Arduino Chipsets
parachaser
parachaser over 6 years ago
How many of you have come across the CH340 chipset.? Purchased a couple nano boards with the CH340 chipset trying to find the correct drivers and getting them to work on a windows PC is a nightmare. after a couple of days of finally getting the driver situated having issues loading codes..
  • parachaser
    parachaser over 6 years ago in reply to aswinvenu +2
    Hello Mr Venu, I have spent countless hours getting the boards to work.. countless hours on Arduino forums trying to decipher one error message to the next.. The thing is my friend that kind of thing should…
  • BigG
    BigG over 6 years ago +1 suggested
    Ah the CH340. Often found on Nano clones. Apparently, the cheapest USB to serial chip on the market. What exactly did you try on Windows 10 (assuming you're using Windows 10).
  • aswinvenu
    aswinvenu over 6 years ago in reply to parachaser +1
    Can you provide some more info regarding the issue you faced while loading the application code? what does the log say? Regards, Aswin
  • BigG
    0 BigG over 6 years ago
  • aswinvenu
    0 aswinvenu over 6 years ago
    Hi Mike,
    Did you follow these instructions?
    https://sparks.gogo.co.nz/ch340.html
    Aswin
  • parachaser
    0 parachaser over 6 years ago in reply to BigG
    Using windows 7 Finally I was able to get the drivers to load then had issues with code loading... I will never purchase another CH340 chipset again.. I never had any issues such as those using the original Arduino boards.. Lesson learned,!
  • parachaser
    0 parachaser over 6 years ago in reply to aswinvenu
    Using windows 7 Finally I was able to get the drivers to load then had issues with code loading... I will never purchase another CH340 chipset again.. I never had any issues such as those using the original Arduino boards.. Lesson learned,! The nano boards I have tossed in my junk parts box. They are simply not worth the frustration even though they are cheap .. It stands true you get what you pay for.
  • aswinvenu
    0 aswinvenu over 6 years ago in reply to parachaser
    Aswin
  • parachaser
    Hello Mr Venu, I have spent countless hours getting the boards to work.. countless hours on Arduino forums trying to decipher one error message to the next.. The thing is my friend that kind of thing should never happen in the first place.. With the original Arduino chipset I never have an issue that should pretty much say a great deal.. With all due respect I no longer have any desire to mess with it again.. Thank you so much for your attempts at helping me find resolution I appreciate it very much.. Time to move on  !
