Arduino Forum Sending words trough serial
  • Subscribers 416 subscribers
  • Views 328 views
  • words
  • trough
  • serial
  • sending
dirtdiver
dirtdiver over 14 years ago
Hello everyone,
Can I send words trough serial . like when I send the word "go" the arduino receives "go" and do whatever its programed to do.
I obviously cant use
int val =  Serial.read ();
So i need someting like
text val = Serial.read ();          // i dont know how to switch the int with a text input
//and
if (val == go){
do something
  • billabott
    billabott over 14 years ago +1
    This snipet of code from my morsecode generator project should enlighten you. const unsigned int MAX_MESSAGE_LEN = 128; const unsigned int BAUD_RATE = 9600; const int LINE_FEED = 13; char message_text…
  • billabott
    0 billabott over 14 years ago
    char message_text[MAX_MESSAGE_LEN];
    int index = 0;
    void setup() {
      Serial.begin(BAUD_RATE);
    void loop() {
      if (Serial.available() > 0) {
        int current_char = Serial.read();
        if (current_char == LINE_FEED || index == MAX_MESSAGE_LEN - 1) {
          message_text[index] = 0;
          index = 0;
          if (message_text == "go") {
              GoDoSomething();
        else {
          message_text[index++] = current_char;
    N.B.  There are probably other ways to do the input buffer read but this way works for me in this app.
    Syntax matters.
    I need the 50 points for the correct answer. Thanks.
