Arduino Forum Midas I2C LCDs
  • Replies 21 replies
  • Answers 8 answers
  • Subscribers 421 subscribers
  • Views 5460 views
  • lcd
  • i2c
Midas I2C LCDs
Workshopshed
Workshopshed over 14 years ago
Has anyone tried connecting up one of these I2C LCDs to their Arduino?
MIDAS - MCCOG21605B6W-BNMLWIMCCOG21605B6W-BNMLWI - LCD, COG 2X16, NEG STN, W B/L, I2C  - Order Code: 20632092063209
I've got as far as looking at the Wire library http://arduino.cc/it/Reference/Wire and the LCD hardware page http://arduino.cc/playground/Code/LCD  and reading http://www.robot-electronics.co.uk/acatalog/I2C_Tutorial.html
I've also watched Jeremy's videos but they are not totally relavent as they are looking at different things
http://www.element14.com/community/videos/3015/l/tutorial-13-for-arduino-liquid-crystal-displays
http://www.element14.com/community/videos/1828/l/Tutorial-07-for-Arduino:-I2C-and-Processing
I think I'm happy with the wiring it up, pull up resistors etc. I'm also guessing it will require an external psu to be hooked up.
I've not yet ordered the display so it might be straight forward when I get it but just getting as much help as I can before getting going.
  • Workshopshed
    Workshopshed over 14 years ago +3 verified
    I got this working just fine. There were a couple of things I needed to do, firstly, for this particular model, Midas told me the backlight needs to be on for the text to be visible. I also had some fun…
  • Workshopshed
    Workshopshed over 14 years ago in reply to bobcroft +1 suggested
    Bill, I'm only using one display so don't need a multiplexer or switch but it's good to know those exist. Bob, cheers for the link, it's not working just this second but I'll check it out again. It's good…
  • fustini
    fustini over 14 years ago in reply to billabott +1
    Thanks for the link. I'm thinking this would be useful for embedded Linux computers, too, like the Raspberry Pi which have I2C but limited GPIO.
  • billabott
    0 billabott over 13 years ago in reply to e14 Contributor
    Sorry, No.
    It seems to be pretty well explained on AndyC's link: http://www.workshopshed.com/2012/07/a-little-venture-with-electronics-lcd.html
    Give it a try with
    • ST7036 lcd = ST7036 ( 2, 16, 0x7C );
    changed to
    • ST7036 lcd = ST7036 ( 2, 24, 0xXX );
    Let us know what you find.
    0 mcb1 over 13 years ago in reply to billabott
    I have been using the I2C range of LCD's for a while.
    They are basically a normal LCD with a board on the rear, that incldes 3 address jumpers.
    There are two chip options and each default to different I2C addresses, so you need to check.
    Just a note to anyone considering these.
    The White on Blue is slower at changing characters, probably because its actually reverse. ie it allows the backlight through, rather than blocking it.
    If you have a need to have scrolling, then consider the green/black or the other options or put up with slowing it down to stop the 'ghosting'.
    I haven't looked lately at E14 but they are in the order of US$10-12 from a number of suppliers.
    mark
  • Workshopshed
    0 Workshopshed over 13 years ago in reply to mcb1
    I had a very quick look at the RW1062 data sheet vs the ST7032 data sheet and the commands I looked at such as clear screen seemed to be the same. So I'd think that trying it with the ST7036 library would be a good starting point.
    Mark, I had seen the codes for making the display scroll but have not tried them, useful to know about scrolling on reversed screens.
    0 mcb1 over 13 years ago in reply to Workshopshed
    Andy
    Have a look at the sketch here and how to do partial scrolling of some characters.
    I have used it for error messages, where the errors text is formulated based on each error, and then scrolled.
    Obviously this is a just a demo of one way to do it.
    http://www.theshedmag.co.nz/online/images/stories/downloads/arduino/Relay_with_I2C_LCD.zip
    The whole article is available at http://www.theshedmag.co.nz/online/images/stories/downloads/arduino/arduino-101-part4.pdf
  • Workshopshed
    You write for Shed Magazine, kudos!  I had a copy send over the other year.
    Andy
    Which one.?
    I subscribed and then offered something that didn't require a full knowledge of electronics.
    It went from there, to being introduced to Arduino by Jude Woodside, and then to articles in nearly every issue since.
    We currently doing RaspberryPi 101 ...so its a step learning curve.
    Its actually been great fun as well as learning some additional skills, and being compensated for my hobby.
    He does do an electronic subscription ...
    mark
  • Workshopshed
    I have August-September 2011, I do hope at some point to write something for Model Engineer's Workshop but don't get a lot of time for metalworking at the moment.
    http://www.theshedmag.co.nz/online/components/com_virtuemart/shop_image/product/August_September_4e30888239f2b.jpg
    Andy
    First Arduino article was a Wordclock in the Dec/Jan 2012 issue , that Doug Jackson in Australia produces.
    http://dougswordclock.com/about/
  • joe1990
    0 joe1990 over 7 years ago
    Does not work, I just get the error: undefined reference to `ST7036::ST7036(unsigned char, unsigned char, unsigned char)
  • Workshopshed
    0 Workshopshed over 7 years ago in reply to joe1990
    Hey Joe, are you using the Arduino desktop or web IDE for this?
