Arduino Forum schematic help
  • Replies 16 replies
  • Answers 2 answers
  • Subscribers 418 subscribers
  • Views 2263 views
  • jammer
  • fm
  • transmitter
schematic help
dirtdiver
dirtdiver over 14 years ago
Hi everyone,
now my question isnt arduino related , but i couldnt get the answer somewhere else so i thought that some of you guys might know the answer.
OK so i have a schematic for an FM jammer/transmitter - its both as it jamms the signal by transmitting nothing.
I want to change that nothing to a something (and i know for a fact that its posible with that schematic)So I need to hook up a 3.5mm jack somewhere on that schematic, my gues would be to connect it between the 0.01uF cap and GND , but am I correct? if not do you know where am i supposed to connect it to?
Again sorry that its not arduino related but any help is highly appreciated!
    e14 Contributor over 14 years ago in reply to dirtdiver +1
    You are building an FM transmitter. You don't put an ear piece on the transmitter thats what the receiver is for.
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to R_Phoenix
    the male 3.5 mm jack image
    0 e14 Contributor over 14 years ago in reply to dirtdiver
    Like i said you can place any kind of connector you want in place of the mic. Whatever connector you feel you need to get audio into the circuit.
    0 michaelkellett over 14 years ago in reply to e14 Contributor
    I must be getting old but I think I should point out that it is almost certianly illegal to operate this cicruit in most places in the world - it's certainly rather antisocial to do so where the signals might interfere with other people's legal use of the RF spectrum.
    Michael Kellett
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to michaelkellett
    as far as i know in bulgaria its legal as long as it doesnt have an antena, but thanks for the concern image
    and that is intended for practical jokes
    0 e14 Contributor over 14 years ago in reply to michaelkellett
    From what I've read the power output doesn't exceed the FCC regulations here in the US for an FM transmitter. The circuit diagramed above wouldn't be able to transmit more then 50 feet. Its a very basic DIY version of an FM transmitter for an MP3 player like this one. As long as the transmitter doesn't exceed 10 watts or interfere with other local broadcasts it is well within the FCC guidelines. You would need a much more powerful transmitter and larger antenna to start hitting FCC regulations. The circuit diagramed above is very similar to one i use to play with as a kid on my 150 in one electronics project kit from Radio Shack. But i had to be almost right on top of the radio to get the signal through.
    Hello Michael,
    I'm not familiar in detail with the FCC regs (although I think it will 10mW for unlicensed) but there are usually regs relating to power output,  frequency and harmonics. The problem with a DIY circuit like this is that you won't know what's coming out. In Europe to a first approximation) if you can pick it up on a normal radio it's illegal. Of course if you don't bother anyone with it no one will know and there won't be any problems.
    Michael Kellett
