Arduino Forum 2 pots as One
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 418 subscribers
  • Views 1799 views
  • bypass
  • potentiometer
  • rc
  • heli
2 pots as One
dirtdiver
dirtdiver over 14 years ago
Hi everyone,
I have posted that question on many EE forums , but it remains unanswered and thats why im posting it here- i think some people here will be able to come up with something.
Anyway heres the deal- An rc helicopter remote controller has a potentiometer for roll, pitch and yaw movement
Im interested in the Yaw movement - im building a cockpit and i cant figure out how to split that pot into two pots (yaw is controlled by two pedals in a real heli)
I need to come up with a mechanical or electrical solution...so far i have came up with this idea - there will be a micro switch on each pedal + the pot.
When , say left pedal is pressed the switch bypasses the second pedal's pot and its like its not there and vice versa, but im not sure how reliable would that be
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to dirtdiver
    but then again that wont affect the resistance between 5v and gnd
    i cant seem to understand the danger here image
    holy *** image am so dumb sometimes... if the first "rotator" bypasses the "resistance"(between theGND and 5 - 10k foe e.g.) of the first pot and the same thing happens to the second pot thats the short circuit..
    Message was edited by: L V
  • dirtdiver
    Wrong intel image a friend of mine has a flight sim controllers including the rudder pedals, and at his set they are independent - you push one down - the other doesnt move, but after some digging, i found out that ina real heli when you press a pedal the other one comes towards you , so that wont be something i want to avoid anymore image and one pot is all i need
  • YT2095
    0 YT2095 over 14 years ago in reply to dirtdiver
    yup, and they do in a plane as well, I didn`t mention the see-saw for design convenience alone, but for realism image
    the only sort of thing (in a twin engine+, plane anyway) that has anything like individual controls like that is the throttles, and you can use these to effect Yaw as well, although that`s an aside, and not really applicable to helis.
    IIRC Yaw`s effected by altering the tail rotor speed in those.
    pity you lived so far away, it would be fun to weld up a mechanical for the pedals as realistic as possible!
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to YT2095
    yep thats too bad..all i can do for now is let you know how it goes image
