Arduino Forum Please, could some help me with this compiling error?
  • Subscribers 416 subscribers
  • Views 403 views
I do not understand this error:
ebl_RTC_Logging_BMP085.ino: In function 'void loop()':
ebl_RTC_Logging_BMP085:158: error: expected unqualified-id before string constant
156 //Create Data string for storing to SD card
157 //We will use CSV Format
158  String dataString = "(id) + ", " + String(Temperature_degF)+ ", " + String(Pressure_inHG) + ", " + String(atm) + ", " + String(Altitude_Ft) + ";
William
  • cookieglitch
    cookieglitch over 13 years ago +1
    At a glance, the problem seems to be a little mix up with where " is used in relation to concatination of string literals and variables. Put simply, the " need to be going around anything that doesn't…
    e14 Contributor over 13 years ago in reply to cookieglitch +1
    I think John is correct that your quote marks are mixed up, and what you think is inside the quotes is actually outside them, and vice versa. As a general suggestion, when you get a mysterious error message…
  • cookieglitch
    0 cookieglitch over 13 years ago
    At a glance, the problem seems to be a little mix up with where " is used in relation to concatination of string literals and variables. Put simply, the " need to be going around anything that doesn't change, such as the commas used in CSV format. Correcting that you should get something like
    String dataString = id + ", " + String(Temperature_degF)+ ", " + String(Pressure_inHG) + ", " + String(atm) + ", " + String(Altitude_Ft);
    You'll just need to adjust that to match the format you need for the CSV file, such as line endings, appropriate use of white space (http://en.wikipedia.org/wiki/Comma-separated_values)
    This might help with your issue, give it a go and let us know! image
    0 e14 Contributor over 13 years ago in reply to cookieglitch
    As a general suggestion, when you get a mysterious error message from
    something complicated like this, try making it gradually simpler and simpler.
    In the process, either the error message will go away at some point,
    and then look closely at what you just changed.  Or the error message
    will still remain on a much simpler statement, in which case the cause
    will be much more obvious.
