Arduino Forum Problem with code loading
  • Subscribers 416 subscribers
  • Views 747 views
  • lcd
  • tft
  • touchscreen
I cannot get the ContemplatorNV.ino code to down load from the Nuts& Volt article. I have tested out the complier on an Arduino Uno on code I know works. This at least proves the compiler, USB connection and Arduino are working. I then switched to the Mega 256 and recompiled the known programs and downloaded them. This also worked. So I went back to the demo programs,it worked well from this page However, I still cannot get the code to down load from the Nuts& Volt article. I get these errors:
Binary sketch size: 40,416 bytes (of a 258,048 byte maximum) avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer
Has anyone tried that code?
ContemplatorNV.ino.txt.zip
    I HAVE THISE CODE AND I TRIED IT AND IT WORK DONE  BUT I CANT UNDER STAND THE CODE ,I NEED SOME INSTERUCTION AND BAISC TO UNDER STAND IT
    THISE IS THE CODE THAT I HAVE.
    CODE FOR MPU_6050
    // MPU-6050 Accelerometer + Gyro
    most "stk500..." error is caused by choosing the wrong "Board" or wrong "Serial port".
    check the arduino ide tool bar see if they are match with the board you were using.
    if this still can't solve your problem, you could read this post.
    http://www.sainsmart.com/vanilla/discussion/84/about-avrdude-stk500_getsync-not-in-sync-resp0x00-error#Item_2
    @islam
    just this?
