Arduino Forum Arduino programming help
  • Subscribers 417 subscribers
  • Views 374 views
Hey guys whatsup, i am new to this forum and have decided to post due to some difficulties i am having with a current project. Everything was working quite smoothly but the addition of the manual buttons has cause a problem, Whats happens is that now i am only able to get one output, for instance if i cover the light sensor, the roof will close, and nothing else. It stays right there, takign my hand off will make no difference in outputs.
Below is my code, i haven't been coding much before so excuse my code if its a bit noob, also, before i used only if else statements, seeing as most of the code now relies on the outcome of the manual button i decided to use while statements with if else. Below is my code,any help would be greatly appreciated.
#include <PID_v1.h>
#include <LiquidCrystal.h>
#include <DHT.h>
#define DHTPIN 8
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
double Setpoint, Input, Output;
PID myPID(&Input, &Output, &Setpoint,0.5,0.5,0.5, DIRECT);
PID myPID1(&Input, &Output, &Setpoint,0.5,0.5,0.5, DIRECT);
Declaring of Variables
int counter1=0;
int counter2=0;
int counter3=0;
int lightsensor = A0; //light sensor input
int rainsensor1 = A1; //rain sensor1 input
int rainsensor2 = A2; //rain sensor2 input
int openingroof = 53; //Output for opening for roof
int closingroof = 51; // Output for closing roof
int turningbeans = 52; //output for bean turner
int piezo = 7;          //Output for piezo
int lightsensorval = 0;
int rainsensorval1 = 0;
int rainsensorval2 = 0;
char incoming_char;
int manual_stop = 22;
int manual_stopled = 24;
int manual_bturner =26;
int manual_open = 28;
int manual_close=30;
int manual_stopvalue = 0;
int manual_bturnervalue=0;
int manual_openvalue = 0;
int manual_closevalue=0;
int test =0;
float h = 0;
float t = 0;
int cellmessage;
unsigned long currentTime;
unsigned long loopTime;
void setup()
currentTime = millis();
loopTime = currentTime;
delay(60000);
Serial.begin(9600);
Serial1.begin(9600);
//setting outputs and inputs
pinMode (lightsensor,INPUT);
pinMode (rainsensor1,INPUT);
pinMode (rainsensor2,INPUT);
pinMode (openingroof,OUTPUT);
pinMode (closingroof,OUTPUT);
pinMode (turningbeans,OUTPUT);
pinMode(piezo,OUTPUT);
pinMode (manual_stop,INPUT);
pinMode (manual_stopled,OUTPUT);
pinMode (manual_bturner,INPUT);
pinMode (manual_open,INPUT);
pinMode (manual_close,INPUT);
//ti.pulse(piezo,3000,Piezo);
lcd.begin(16, 2); //setup of LCD's rows and columns
dht.begin();
Input = dht.readTemperature();
Setpoint = 75;
myPID.SetMode(AUTOMATIC);
Input = dht.readHumidity();
Setpoint = 55;
myPID1.SetMode(AUTOMATIC);
void sendSMSOPEN()
  Serial1.println("AT+CMGF=1");
  delay(500);
  Serial1.print("AT+CMGS=");
  Serial1.write((byte)34);
  Serial1.print("18687914655");
  Serial1.println();
  delay(500);
  Serial1.print("Sunlight Detected,Roof Opening, Heater is ON, Bean Turner is ON. Have a good day.");
  delay(500);
  Serial1.write((byte)26);
  Serial1.println();
  delay(500);
void sendSMSCLOSE()
  delay(500);
  Serial1.println();
  delay(500);
  Serial1.print("Sunlight Not Detected,Roof Closing, Heater is ON, Bean Turner is ON. Have a good day.");
  delay(500);
  Serial1.println();
  delay(500);
void sendSMSMANUAL_STOP()
  delay(500);
  Serial1.println();
  delay(500);
  Serial1.print("Manual Stop has been activated");
  delay(500);
  Serial1.println();
  delay(500);
void loop()
  lightsensorval=analogRead(lightsensor);
  delay(10);
  Serial.print("Light sensor value =");
  Serial.println(lightsensorval);
  rainsensorval1=analogRead(rainsensor1);
  delay(10);
  Serial.println("Rain sensor1 value =");
  Serial.println(rainsensorval1);
  rainsensorval2=analogRead(rainsensor2);
  delay(10);
  Serial.println("Rain sensor2 value =");
  Serial.println(rainsensorval2);
   h = dht.readHumidity(); //reading of humidity
  t = dht.readTemperature(); // reading of temperature
  myPID.Compute();
  analogWrite(9,Output);
  myPID1.Compute();
  analogWrite(10,Output);
  manual_stopvalue = digitalRead(manual_stop);
  delay(10);
  manual_bturnervalue = digitalRead(manual_bturner);
  delay(10);
  manual_openvalue = digitalRead(manual_open);
  delay(10);
  manual_closevalue = digitalRead(manual_close);
  delay(10);
Serial.print("Manual Stop=");
Serial.println(manual_stopvalue);
//delay(1000);
Serial.print("Manual Bean Turner=");
Serial.println(manual_bturnervalue);
//delay(1000);
Serial.print("Manual Roof Open=");
Serial.println(manual_openvalue);
//delay(1000);
Serial.print("Manual Roof Close=");
Serial.println(manual_closevalue);
//delay(1000);
lcd.setCursor(0,0);
lcd.print("TEMP=");
lcd.print(t);
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("HUMIDITY=");
lcd.print(h);
lcd.print("%");
lcd.print(" ");
while (manual_stopvalue == 0)
if (rainsensorval1 <= 200 || rainsensorval2 <= 200 || lightsensorval <= 300)
  digitalWrite (closingroof,HIGH);
digitalWrite (openingroof,LOW);
digitalWrite (turningbeans,HIGH);
digitalWrite (manual_stopled,LOW);
counter1++;
counter2=0;
counter3=0;
 if (counter1==1)
  sendSMSCLOSE();
    //delay(200);
    //analogWrite(piezo,128);
//delay(3000);
//analogWrite(piezo,LOW);
else if (rainsensorval1 > 200 && rainsensorval2 > 200 && lightsensorval > 300)
digitalWrite (openingroof,HIGH);
digitalWrite (closingroof,LOW);
counter2++;
counter1=0;
counter3=0;
if (counter2==1)
sendSMSOPEN();
//delay(3000);
delay(10);
delay(10);
delay(10);
while (manual_stopvalue == 1)
delay(10);
delay(10);
delay(10);
delay(10);
  digitalWrite(manual_stopled,HIGH);
  counter3++;
  counter1=0;
  counter2=0;
  if (counter3 <= 1)
  sendSMSMANUAL_STOP();
  //delay(3000);
  if (manual_bturnervalue ==1 && manual_openvalue == 1  && manual_closevalue== 1)
  digitalWrite(turningbeans,LOW);
  digitalWrite(openingroof,LOW);
  digitalWrite(closingroof,LOW);
else if (manual_bturnervalue == 0 && manual_openvalue == 1 && manual_closevalue==1)
  digitalWrite(turningbeans,HIGH);
else if (manual_bturnervalue == 1 && manual_openvalue ==0 && manual_closevalue ==1)
    digitalWrite(openingroof,HIGH);
else if (manual_bturnervalue ==1 && manual_openvalue ==1 && manual_closevalue==0)
  digitalWrite(closingroof,HIGH);
else if (manual_openvalue ==0 && manual_closevalue ==0 && manual_bturnervalue ==0)
else if (manual_bturnervalue == 0 && manual_openvalue == 0 && manual_closevalue==1)
else if (manual_bturnervalue == 0 && manual_openvalue == 1 && manual_closevalue==0)
else if (manual_bturnervalue == 1 && manual_openvalue == 0 && manual_closevalue==0)
    wooooooohooooo,nevermind i got them working,did alot of fiddling. one questions though, anyone know how i can get the delays off the sms function?? its causing a bit of a delay with the program.
    0 mcb1 over 13 years ago in reply to e14 Contributor
    Navin
    If you can use millis() and do a time comparison to see if enough time has passed (ie a delay).
    At the start of you 'delay' you note the millis(), then read millis() and subtract your recorded value.
    If the result is greater than xx then continue.
    You can have as many as you want, but you need a long int to hold the recorded value.
    The "BlinkWithoutDelay" example will show you.
