I want to use some code which are coming by RF receiver and accordingliny I can hear the music which is store in my SD-memory card connected with controler.
As the code is change, Predefined music will play....
There`s really not enough information in your question for anyone to answer you accurately.
What is the MP3 player you are using? would be the Main thing that needs clarification.
Parsing and RF signal (via a suitable receiver) through an arduino (or any other MCU) into a given output or sequence of outputs to control an MP3 player is perfectly doable, even if you use an Off-the-shelf MP3 player and can solder bi-lateral switches (4066 for instance) across the keypads is perfectly workable
