Arduino Forum Keeping an average in a sketch.
  • Subscribers 416 subscribers
  • Views 787 views
First off, thank you to everyone at the element14 community for professionally answering my novice questions. Its really great that everyone is willing to be so helpful!
This time around, I need a little help on my current project. I am making a arduino clone of a basic bicycle computer. I've got the basics of it set up, and I can accurately output my current speed, and distance traveled. My next goal is to calculate my average speed. The idea of storing all of my speed readings, and trying to average them all as I go weems ludicris. I would quickly fill the arduino up with an array of speeds. I was hoping there is a better way. Has anyone ever needed to do something similar? What would be the best equation to use?
My inital thought was something along the lines of: new average = (previous average + new value) / 2
However, it doesnt seem to be as accurate as properly averaging the numbers.
    e14 Contributor over 13 years ago in reply to ntewinkel +1
    Alright, then a float it is, thanks you very much!
  • ntewinkel
    0 ntewinkel over 13 years ago
    Average = sum_of_all_values / number_of_values
    So you could store one field named something like "sum" and keep adding to it.
    And keep a field named something like "count" and keep incrementing it.
    Then your average will always be sum/count.
    For sum, you should use a "long" datatype or something that can hold really big numbers.
    Hope that helps image
    Cheers,
    -Nico
    0 e14 Contributor over 13 years ago in reply to ntewinkel
    Do I need to worry about storing a potentially huge value like that? If I am adding 15-20 every time the wheel turns, over the course of hours, it would be massive.
  • ntewinkel
    0 ntewinkel over 13 years ago in reply to e14 Contributor
    Unsigned long can handle more than 4 billion: http://arduino.cc/en/Reference/UnsignedLong
    A float is even bigger (power of 38): http://arduino.cc/en/Reference/Float
    I suppose the other way to handle it is to add the fractional change, but that would still require a float to calculate the difference which would ultimately become a tiny tiny fraction.
    Cheers,
    -Nico
  • ntewinkel
    0 ntewinkel over 13 years ago in reply to ntewinkel
    I think your best bet is a float, as you're probably tracking speed with some decimals points so you'd need that anyway.
  • ntewinkel
    ps, I think the formula you had in mind, to directly add to the average every time, would look like this:
    newAverage = previousAverage * (count-1 / count) + newSpeed * (1 / count)
    That would involve 2 multiplications, 2 divisions, 1 subtract, and 1 add.
    The other method requires 2 additions (1 to add to the sum, 1 to increment the counter), and one division.
    Cheers,
    -Nico
