Arduino Forum Y PUTTY NOT SHOW CHAR 3, ARDUINO SERIAL MONITOR & PROCESSING DO
  • Subscribers 417 subscribers
  • Views 673 views
  • uart_to_wifi_convert_module
klong84
klong84 over 12 years ago
I'm using putty to look at BT data from arduino.
The EXT, end of text (ascii code 3), doesn't show up. looks like O that's sq.
I see same in arduino's serial monitor and remove this char in processing 2.1,
this char is also the readuntil in processing. If it was not seen the code
would collapse. putty omits this char, there is no char B/W end and start, it
should be char 3.
Y not seen in putty?
Keith
    I'd recommend using the "Move" button under the Actions heading on the right side
    of your screen, to move this post to the arduino discussion group.  The specified item was not found.
    EXT is a non-printable character.
    The first 31 characters of the ASCII code are all non-printable control codes.
    Take a look at : Ascii Table - ASCII character codes
    So the serial monitor will print anything is thinks it can use to show at least something.
    Henk Siewert
    http://swtrocketry.com
  • klong84
    0 klong84 over 12 years ago in reply to e14 Contributor
    Hi, yes I'm aware of this, Lets say a repeated transmit message of "This is end of tramsmission[char(3)]"  .
    Arduino serial monitor and processing 2.1 will look like:
    This is end of tramsmission[char(3)]This is end of tramsmission[char(3)]This is end of tramsmission[char(3)] ....
    but putty looks like:
    This is end of tramsmissionThis is end of tramsmissionThis is end of tramsmission ...
    with nothing B/W end and the next beginning.
    I just expected something to reflect the presents of the nonprintable char. I just started playing with putty and
    will see if I can learn what it does with this char, .ie does it throw it out?
    Keith
    0 e14 Contributor over 12 years ago in reply to klong84
    Hallo,
    OK, I don't know.
    I use TeraTerm for the VT100 protocol.
    So I can use clearscreen and cursor commands.
    Works perfectly.
    Greetings from The Netherlands,
    Henk Siewert
  • klong84
    Hi Henk,
       Thanks for your replies. I tried teraterm a moment ago, version 4.79. Looked at serial comunication as with putty and get the same
    display. Both tools do not reflect the presence of the non printable char 3.
    Keith
