Arduino Forum Arduino 4 Digit 7-Segment Display Counter
  • Subscribers 416 subscribers
  • Views 1057 views
  • push
  • 7-segment
  • digit
  • segment
  • code
  • counter
  • button
  • display
  • 7
  • 4
silviustro
silviustro over 12 years ago
Hi everyone,
I have recently bought one of these https://www.sparkfun.com/products/11408 4 Digit 7-segment displays, and even tho SparkFun includes a good example for using the display, (right here, btw http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Components/LED/_7Seg_Example.pde) I have failed in modifying the code for my purposes.
I need the display to advance one digit each time i press a push button switch.... as simple as that.
but as simple as it may sound... we all know 7-segment displays use multiplexing, not such a simple interface.
I curentlly used all my shift registers in another project, so i will need to make use of the available Arduino pins (which are more than enough) for this.
Thank you for your answers!
  • silviustro
    0 silviustro over 12 years ago
    Here I have made some preliminary code, problem is, i can't stop the "Void Loop()" function and make it advance just one number per button press.
    //segments
    int a = 1;
    int b = 2;
    int c = 3;
    int d = 4;
    int e = 5;
    int f = 6;
    int g = 7;
    int p = 8;
    //digits
    int d4 = 9;
    int d3 = 10;
    int d2 = 11;
    int d1 = 12;
    //other
    int n = 0;
    int x = 100;
    int del = 500;
    //Button connected to Digital Pin 13
    void setup()
      pinMode(d1, OUTPUT);
      pinMode(d2, OUTPUT);
      pinMode(d3, OUTPUT);
      pinMode(d4, OUTPUT);
      pinMode(a, OUTPUT);
      pinMode(b, OUTPUT);
      pinMode(c, OUTPUT);
      pinMode(d, OUTPUT);
      pinMode(e, OUTPUT);
      pinMode(f, OUTPUT);
      pinMode(g, OUTPUT);
      pinMode(p, OUTPUT);
    void loop()
      clearLEDs();
      pickDigit(1);
      pickNumber((n/x/1000)%10);
      delayMicroseconds(del);
      clearLEDs();
      pickDigit(2);
      pickNumber((n/x/100)%10);
      clearLEDs();
      pickDigit(3);
      dispDec(3);
      pickNumber((n/x/10)%10);
      clearLEDs();
      pickDigit(4);
      pickNumber(n/x%10);
      if (digitalRead(13) == LOW)
        n = n+1;
    void pickDigit(int x)
      digitalWrite(d1, LOW);
      digitalWrite(d2, LOW);
      digitalWrite(d3, LOW);
      digitalWrite(d4, LOW);
      switch(x)
        case 1: digitalWrite(d1, HIGH); break;
        case 2: digitalWrite(d2, HIGH); break;
        case 3: digitalWrite(d3, HIGH); break;
        default: digitalWrite(d4, HIGH); break;
    void pickNumber(int x)
      switch(x)
        default: zero(); break;
        case 1: one(); break;
        case 2: two(); break;
        case 3: three(); break;
        case 4: four(); break;
        case 5: five(); break;
        case 6: six(); break;
        case 7: seven(); break;
        case 8: eight(); break;
        case 9: nine(); break;
    void dispDec(int x)
      digitalWrite(p, LOW);
    void clearLEDs()
      digitalWrite(a, HIGH);
      digitalWrite(b, HIGH);
      digitalWrite(c, HIGH);
      digitalWrite(d, HIGH);
      digitalWrite(e, HIGH);
      digitalWrite(f, HIGH);
      digitalWrite(g, HIGH);
      digitalWrite(p, HIGH);
    void zero()
      digitalWrite(a, LOW);
      digitalWrite(b, LOW);
      digitalWrite(c, LOW);
      digitalWrite(d, LOW);
      digitalWrite(e, LOW);
      digitalWrite(f, LOW);
    void one()
    void two()
      digitalWrite(g, LOW);
    void three()
    void four()
    void five()
    void six()
    void seven()
    void eight()
    void nine()
